Question about Viking DIPR160R Stainless Steel Kitchen Hood
Viking downdraft dipr 160r cable
I need a new cable as one pins were broken off during installation
Thanks a million.
Andy
    Scholar:
  • 110 Answers
IF YOUR MACHINE WAS BROKEN DURING INSTALL YOU SHOULD BE UNDER FACTORY WARRANTY IF IT WAS PURCHASED AT AN AUTHORIZED DEALER IT IS THE RESPONIBLITY TO REPLACE THE MACHINE AND TAKE THE OTHER ONE BACK TO THE STORE TO HAVE A AUTHORIZED SERVICER REPLACE OR REPAIR ANY DAMAGED PARTS. HOWEVER IF THIS IS NOT A NEW INSTALL YOU CAN PURCHASE THE PARTS FROM HADCO APPLIANCE PARTS
Posted on May 30, 2008
I have a Viking downdraft exhaust fan that returns into the counter I need a new circuit board for it keeps going up and down got hit during a lighting storm where can I get one
Call Viking range parts distribution for cost of part in question if it's under 8 yrs old it may be available . 888/845-4641
Jan 20, 2015 | Viking Refrigerators
Microwave door latch
Refer this matter directly to Viking
Jun 07, 2013 | Viking Refrigerators
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
No gas on viking professional. ignitor works downdraft does not
There are solenoids that turn the gas on to a burner. If they're bad it won't supply gas to the burner. There is also a mother board on that model that could also be the problem. When it comes to this brand it's difficult to diagnose without being there. If the downdraft is not working then I would guess that the mother board could be the problem...sorry I couldn't help more.
Aug 27, 2011 | Viking 37 in. VGSU163-6B Gas Cooktop
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Mar 11, 2010 | Viking VIPR101 Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Viking downdraft ventilator electrical problem.
You seem to have a slightly different model, but see a solution at:
it is probably the same thing
May 28, 2009 | Viking VIPR101 Kitchen Hood
Viking 940 Sewing Machine will not run.
the transformer has broken solder connections between the pins for the plug and the transformer board. Brave? 4 phillips screw. Black box on bottom. remove ribllon cable. Transformer out. 2 screws black cover on transformer off. Theres the board with broken solder joints to the plug pins. The large plug they used on that model broke the solder joint easily. it shoudlnt be blowing fuses though unless he tried to fix it and put in wrong one.
Feb 09, 2009 | Husqvarna Viking 1
Viking DIPR160R Stainless Steel Kitchen Hood Logo
200 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
