Question about Car Audio & Video
2002 Chevy Cavalier audio wiring diagram
I need the diagram for a 2002 Chevy Cavalier Stereo. We are trying to hook up a Durabrand CD player, but we don't know what all of the wires are for. Thanx.
T.
  • Anonymous Sep 20, 2008
    I have the same problem, I bought a manuel that has a diagram but there is a purple wire and more than one black wire, should i make all the blacks common
    also I hook the orange wire up to my deck, it turns my deck on but then the deck turns off after a few seconds
To the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
Posted on Sep 08, 2008
  • bikerfoote Sep 08, 2008
    Car Radio Constant 12v+ Wire: Orange
    Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does
    not provide a switched power source. Run a wire from the Ignition
    Switch.)
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Gray
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger: Pink
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Front Speakers Size: N/A
    Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Rear Speakers Size: N/A
    Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
There is also a thin black wire (just another ground wire), and a purple wire. The purple wire is not used in a 2002 Cavalier, and should be capped off and left alone.
Posted on Feb 22, 2009
  • rhcpfan Mar 10, 2012
    is this the same for a 2001 cavalier???
    New Friend:
On my 2002 cavalier, I have a factory Delco amp that runs the dual voice coil 6x9s on the rear deck.my question is, how do you wire the speakers if you are replacing the factory speakers that have 4 wires? I would love to still be able to use the factory amp but when I try to hook them up like in parallel to bridge the amp it shuts down all sound! Is this even possible to do or will I just have to use 2 of the 4 wires per 6x9" speaker to hook up the aftermarket 6x9"s? Any help with this would be much appreciated. I do have it hooked up now using the wire diagram of the 02 cavalier w/o factory amplifier. (It has the same color wires, it just has two extra wires per speaker that I have taped off. Thanks. Bobholsopple@gmail.com
Posted on Mar 27, 2016
    New Friend:
I have an 02 chevy cavialier an i ran an extra wire for the ignition and it still not working it will work if I unplug the plug in the back of the radio but when I turn it off and turn it back on it says check wires I've gone over it four times
Posted on Sep 19, 2015
    Problem Solver:
  • 14 Answers
There is no pink wire on certain models. fyi.
Posted on Feb 01, 2012
  • roy wigg Feb 01, 2012
    certain models do not have the pink wire.
Can i fit a double din touch screen in my cavalier
Posted on Mar 28, 2011
I ran a wire to my ignition switch for the switched power and when I turned the radio on the car ****ed up... the radio seemed to **** all the power?!?!?!?!?!! =S
Posted on Sep 23, 2008
  • NE$$ Jun 04, 2018
    U don't run it direct to ignition switch.....you run the wire to fuse box where ignition fuse is...pull ignition fuse...wrap wire around one of prongs...plug fuse back in ....other end hooks up to red wire on deck...
You guys are ******* useless
Posted on Aug 04, 2008
  • 185 Answers
I really dont under stand what u are askin
Posted on Jun 02, 2008
Need wiring diagram for Kenwood k dc car stereo
It's about 1/3 of the way down on the postings2da0a4a6-10bc-4895-b15d-945674c51ea2.gif Wiring Diagrams
Sep 12, 2014 | Cars & Trucks
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
I have a 1996 chevy cavalier and I am trying to find a free wiring diagram for the audio system. The person who had this car before me messed it all up and I need to figure out what is supposed to go...
1996 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
i know u said u want a pic but you should b e able to do it from this
pls rate
Aug 16, 2010 | 1996 Chevrolet Cavalier
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
How to install a jvc stereo kd-g230 in a chevy trailblazer 2002
First you need to get a wire harness for the Chevy (check Ebay) then follow the wiring instruction inside the package on how to join the spliced wires togother. After joining the wires togother plug the harness in and stuck the JVC into the recess where the old stereo was and thats it, it should play if not you don`t have a good ground, ground the body to the frame.
Dec 19, 2009 | JVC KD-G230 CD Player
I need the wiring diagram for the stock stereo on the 91 caprice
DON'T TRY. REPLACE ALL CABLES BECAUSE IT WILL CAUSE ALTERNATOR NOISE ON YOUR CAR AUDIO SYSTEM- IT WAS SPECIFICALLY DESIGNED TO THE ORIGINAL SET AND DOESN'T WORK FINE WITH OTHER. DO NOT ASK MY HOW I kNOW THIS
Aug 03, 2009 | 1991 Chevrolet Caprice
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Apr 29, 2009 | Car Audio & Video
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
How to hook up my cd player
I have a 2002 Chevy Impala that has a factory stereo. It shows cd buttons but there is not a cd player. There is a tape player. How can I hook up a cd player without tearing up the stereo or pulling all the wires out from the back????
Nov 18, 2007 | Car Audio & Video
Car Audio & Video Logo
14,823 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
