Question about Apple iPod nano
Ipod automatically connects and disconnects repeatedly
3 Suggested Answers
  • 92 Answers
SOURCE: ipod nano wont connect to pc
Try this out
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
then try to change the drive letter:
  1. Open the Control Panel.
  2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  3. Double click on Computer Management.
  4. In the left column, click on Disk Management.
  5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
  6. Click the Change button.
  7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
  8. Click OK.
  9. Click Yes on the confirmation dialog.
  10. Close the Computer Management window.
  11. Restart your computer.
Then try to restore the ipod to factory settings:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
This has to resove your issue
Posted on Feb 04, 2009
  • 35 Answers
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
Posted on Jan 07, 2008
How do i sync ipod with computer or laptop as i have now been trying for 3 hours with no success
How to Sync an Ipod to Your Computer
Things You'll Need:
* IPod
* IPod USB that came with iPod
* Computer
* ITunes
* Mouse
So, you've bought an iPod and are super excited about putting your music on it so you can listen on the go, but you don't know how to start. First you have to figure out how to get your songs to your iPod, then you can listen to your heart's content.
This How To will tell you how you can get moving to the beats sooner than later.
Be sure your iPod is not on "hold". Move the bar at the top of the iPod from hold (at right) to manage or release (at left)
Press the center button on your iPod to turn the iPod on
Connect the flatter, wider connecting piece to the opening on the bottom of your iPod (This may have a minus sign on it)
Connect the USB side of the cord (this piece has what looks like a cactus on it) to the USB port in your computer
ITunes will automatically open. Click on the image of your iPod (at left). This will open your settings for whenever you connect your iPod to the computer.
Initially, it may be easiest to let it automatically update your iPod. A screen will come up to ask you if you would like to automatically sync your iPod. Click "YES".
ITunes will do the rest. The top window will show the progress of the data transfer.
DO NOT disconnect your iPod.
Once the window says "Update Complete", eject your iPod to safely remove it from the computer by dragging the image or icon of the ipod on your computer to the trash (which will change into an eject symbol), or clicking on the eject symbol next to the iPod icon (at left).
Disconnect the cord from the computer and iPod
Listen to your music
Tips & Warnings
These instructions are most useful if you have already installed iTunes and charged you iPod prior to connecting it to your computer.
Do not disconnect your iPod until it says "iPod Update Complete" at the top of the iTunes screen.
Also
I faced the same problem. In fact, you can use an ipod to computer transfer program to help.I personally use Cucusoft iPhone/iTouch/iPod to Computer Transfer.It helps me to transfer my songs/videos/photos/playlists etc from ipod to my new computer directly and safely.It works well for me,you can give it a try.
Free download it at: dvd-video-soft.com/ipodconver...
It even has step-by-step guide on the whole process.
thanks for using fixya...
Jan 10, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
OR
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
The problem is, i want to put music from my laptop onto my apple ipod 4GB a1051, how do i do that please?
The following information has come directly from the apple support web site.
Adding Content Automatically or Manually
There are two ways to add content to iPod nano: ? Automatic syncing: When you connect iPod nano to your computer, iPod nano is automatically updated to match the items in your iTunes library. You can sync all your songs, playlists, videos, and podcasts, or, if your entire iTunes library doesn’t fit on iPod nano, you can sync only selected items. You can sync iPod nano automatically with only one computer at a time. ? Manually managing iPod nano: When you connect iPod nano, you can drag items individually to iPod nano and delete them individually from iPod nano. You can add songs from more than one computer without erasing songs from iPod nano. When you manage music yourself, you must always eject iPod nano from iTunes before you disconnect it.
The following URL will bring you to the iPod Nano manual. For more information on setting up you iPod see chapter 2: Setting up iPod Nano
http://manuals.info.apple.com/en_US/iPod_nano_5th_gen_UserGuide.pdf
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 02, 2010 | Apple iPod nano
I need the instruction on how to set up my
here's the website: http://support.apple.com/manuals/#ipod
you can download the user manual from there.
Dec 31, 2009 | Apple iPod nano
Ipod woulnt connect to itunes
Reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Then connect it to your computer and see if it is recognized by iTunes.
If not, try other USB ports on your computer, especially any on the back panel.
Dec 29, 2009 | Apple iPod nano
I cannot delete music off ipod nano 8gb help me please
iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
Products Affected iTunes, iPod nano (3rd generation), iPod classic, iPod (5th generation)
Syncing videos automatically Connect your iPod to your computer and open iTunes. Select your iPod in the DEVICES section of the iTunes Source list.
In the main iTunes browser window, select the Music tab. Select the checkbox labeled "Sync music" and verify that the "Include music videos" checkbox is also selected. You have the option to sync all songs and playlists or selected playlists.
Movies can be automatically synced to iPod. Select the Movies tab and select the option to sync all movies, selected movies, or a certain number recent unwatched movies.
TV Shows can be automatically synced to iPod. Select the TV Shows tab and select the option to sync all TV shows or selected ones. You can also determine which episodes are synced based on if they are recent or unwatched.
Video Podcasts can be automatically synced to iPod. Select the Podcasts tab select the option to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new or unplayed.
Click Apply and iTunes will begin syncing the content you've selected to your iPod. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
The iTunes LCD will display the sync progress and notify you when the iPod sync is complete.
To disconnect your iPod, select it in the Source list and click the eject icon.
Syncing videos manually If your prefer not to automatically sync video content to your iPod, you can setup manual syncing.
In the main iTunes browser window, select the Summary tab. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.
Click Apply. To manually add music videos, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a video or song.
When you are ready disconnect your iPod, select it in the Source list and click the eject icon.
Mar 01, 2009 | Apple iPod nano
Dont know how to recodd on my ipod nano 8GB
If you do not already have iTunes you will need to go to www.apple.com/downloads
and download it there.
Ipod nano not show (not play) songs
Feb 19, 2009 | Apple iPod nano
3rd gen nano 4gb
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Jun 01, 2008 | Apple iPod nano
Jan 07, 2008 | Apple iPod nano
Apple iPod nano Logo
836 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
