Need codes to program my universal remote control it is made by living solutions, it is a backlit touch panel a17g0200 item 564351
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
centralhigh
  • 260 Answers
SOURCE: RCA Universal #RC402A
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Posted on Jun 25, 2008
SOURCE: Living Solutions Remote - Manual
press and hold Tv VCR or DVD wait until the red light turns on then press power. Now press channel up or down until the the device turns on if you press it again while the device is on you'll have to do it again. After that hit OK then test it by pressing the volume button
Posted on Jan 19, 2009
SOURCE: Need Code for Olevia LCD TV
my vizio tv came with the remote code in the manual and it worked on the direct tv rc64 remote
Posted on Jun 14, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
I have a living solutions giant remote A17G0200 (Item 564351) I can't program this to my Emerson flat screen model # LC260EM2 can someone help me
1038,1026,1019. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jun 21, 2015 | Emerson Televison & Video
Living solutions
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
May 13, 2014 | Living Solutions Backlit Touch Panel...
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
Oct 08, 2010 | Universal Remote Control Remote Control
Unable to program Directv universal remote for tv
The RC64RB has more codes in it. Unfortunately, it is an extra $25. BUT, it is backlit, which is very cool at night. With my RC64RB, I get 16 codes to enter for your TV (Emerson HDTV).
Dec 29, 2008 | Universal Remote Control DIRECTV Universal...
there is no code for olevia.....(olevia, vizio and dynex are really new) All universals are not yet ready for theses new flat panels.............but you can use olevias remote (rc-ltu) it controls five units (cable box, olevia tv, pioneer laser disc and toshiba dvd plus a vcr if i had one)
Dec 20, 2008 | Directv RC23 Remote Control
Code list for universal remote control-name brand is living solutions
This is what the manual says: Prgoramming the remote using PowerScan: 1. Manually turn OFF the device you wish to program (TV, VCR, DVD) 2. Press and hold the apprpriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the Remote is in Programming mode. 3. Press and release the power key. The LED flashes once and stays ON, indicating that the remote is in PowerScan mode. 4. Press either the CH+ or CH- key Button repeatedly until the device switches ON. The CH+ Button searches upward in the code list, while the CH- key searches downward. (So since I have a Toshiba tv, I elected to search upward to get to 'T' faster. 5. When the device turns on, press and release the OK Button to store the new code and exit. To exit without setting the code, press the GO BACK Button. NOTE: If you press CH+ or CH- again after the device turns on, the device will not be programmed; you will need to repeat Steps 1-5 again. 6. Press and other operable key (VOL+/VOL-). If the device responds, no further programming is required. If not, repeat Steps 1-5.
Jun 08, 2008 | Big Button TV Universal Remote
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
