Question about LG Computers & Internet
OSD VERROUILLAGE POP UPS - LG Computers & Internet
3 Suggested Answers
  • 670 Answers
SOURCE: how do i get rid
The OSD menu pops up when the menu button is pressed. If they are showing up without any buttons pressed, that means that the menu button is faulty. Sometimes dust and dirt build up on the control panel will cause this to occur. To fix you will need to open the lcd case and check the buttons for debri.
To open most lcd monitors, you will need to detach the stand and any screws that may be holding the case together. Then turn the monitor unside down and open the case by using something thin like a putty knife to seperate the two halves of the plastic case. This is a video that shows you how repair an lcd power supply. You only need to view the first two minutes to show you how to open the case, ignore the rest of the video. http://www.youtube.com/watch?v=9Q6_TgNJvQw.
Once you get the case open check the button with a meter to check that the button is open circuit when not pressed and continuity when the button is pressed. If it does not change state as the button is pressed, you can try to clean it with a cotton swab dipped in 70% isopropol alcohol.
Hope this helps you.
Posted on Jan 08, 2011
SOURCE: continual pop-ups saying OSD Main Control locked
I held down the OK button for several seconds and the message vanished. On releasing the OK button, the problem reappeared. I intend to put a rubber glue (one that can be removed) which hardens on application, to hold down the OK button in the pressed position. Hope this solves the problem.
Posted on Jul 29, 2010
HOW to turn off popup blocker in IE
Pop-up Blocker limits or blocks pop-ups on sites that you visit. You can choose the level of blocking you prefer, turn on or off notifications when pop-ups are blocked, or create a list of sites that you don't want to block pop-ups on. Pop-up Blocker settings only apply to Internet Explorer.
To turn Pop-up Blocker on or off
  1. Open Internet Explorer, select the Tools button , and then select Internet options.
  2. On the Privacy tab, under Pop-up Blocker, select or clear the Turn on Pop-up Blocker check box, and then select OK.
Block all pop-ups
  2. On the Privacy tab, under Pop-up Blocker, select Settings.
  3. In the Pop-up Blocker settings dialog box, under Blocking level, set the blocking level to High: Block all pop-ups (Ctrl + Alt to override).
  4. Select Close, and then select OK.
Turn off notifications when pop-ups are blocked
  3. In the Pop-up Blocker settings dialog box, clear the Show Notification bar when a pop-up is blocked check box.
support microsoft com
Jun 04, 2017 | Computers & Internet
How do you stop pop ups?
Pop-ups are not annoying but may damage your system if you don't get rid of them timely. Research shows that pop-ups may distribute malware or other malicious programs. Be careful! Usually, pop-ups are generated by adware program. So in first step, you should check your installed programs and uninstall any suspicious programs. If the pop-ups still appears and disturbs your browsing history, you can reset your browser to default settings to stop them. If the above manual way is useless, try running a powerful malware remover to remove those annoying pop-ups. More information at:
/http://guides.uufix.com/how-to-remove-onclkds-com-pop-ups/
Mar 07, 2015 | Gateway Computers & Internet
How do I stop all those pop ups on my laptop?
If u are using chrome then search for adblock extension in chrome store and install it. It will block most of pop ups and ads on chrome and firefox.
May 03, 2014 | Acer Aspire Computers & Internet
How do I enable pop ups?
You can allow all pop-ups by disabling the pop-up blocker. Follow these steps:
  1. Click the Chrome menu on the browser toolbar.
  2. Select Settings.
  3. Click Show advanced settings.
  4. in the "Privacy" section, click the Content settings button.
  5. In the "Pop-ups" section, select "Allow all sites to show pop-ups." Customize permissions for specific websites by clicking Manage exceptions.
Nov 27, 2013 | Google Chrome
Compatibility problem?
What does it say ?
are you on the internet when it pops up ?
Internet pop-ups can be an annoyance.
These windows are usually associated with different forms of advertisements and at times can include viruses that can infect the computer.
Pop-ups do not have to be a part of computer use if the user does not desire this distraction. There are ways to stop pop-ups and prevent them from appearing unless desired.
Pop-up blocker allows the user to block these items and select which items to allow. Open Internet Explorer.
Click "Tools" from the menu bar. Tools can be found on the bar that lists "File, Edit, View, Favorites, Tools, Help" directly beneath the address bar.
Click "Internet Options" from the "Tools" menu.
Click the "Privacy" tab in the "Internet Options" box.
Click to check the box that says "Turn on pop-up blocker" in the "Pop-up Blocker" section of the menu.
Click "Apply" to save changes.
Click "OK" to close the "Internet Options" box.
The computer will now block all pop-ups from websites.
If downloading items from the Web, the computer will ask whether you would like to allow these items to be opened.
IE: 8 right click in the top toolbar select the command bar this will add it to the toolbar then on the far right hand side select the tools then from the drop down list pop up blocker make sure its turned on and settings
hope this helps
It's easy to learn how to stop pop ups, and you don't need to download pop up blocking software to get rid of those annoying ads. Just try these easy fixes before downloading a pop up blocker.
The first three methods assume you can use the software you already have. It's quick and simple, and you won't need any add-ons with these methods.
It takes only a few minutes to stop pop ups yourself, even if you are not technically oriented. If Internet Explorer 7 (IE7) or Mozilla Firefox on a Windows Vista computer but these steps should work for any Windows compatible computer (although it may vary some if you have a different version of IE).
Here are four easy and quick ways to stop pop ups on your computer. You can use any one (or more) of these methods to get rid of those pesky pop up ads within minutes.
How to Stop Pop Ups - Method #1: Use Your Settings on Internet Explorer 7
Step 1: On Internet Explorer 7, go to "Tools", then "Internet Options"
Step 2: Click on the "Privacy" tab
Step 3: On the bottom, under "Pop-up Blocker", click the checkbox to "Turn on Pop-up Blocker". Click "Ok".
How to Stop Pop Ups - Method #2: Use a Different Internet Browser (Firefox)
Try using Mozilla Firefox instead of IE because Firefox automatically blocks pop up windows (unlike Explorer). You can download Firefox at http://mozilla.current-version.com.
How to Stop Pop Ups - Method #3: Use Your Web Toolbar
You may already have the google or MSN toolbar installed on your browser. If you try this approach, you may also want to read my articles on how to stop pop ups with your Google toolbar and MSN toolbar.
How to Stop Pop Ups - Method #4: Download a Paid or Free Pop Up Blocker
If you've tried the above steps, and you're still having issues, then you should consider downloading a pop up blocker program.
Two reliable free pop up blockers include the Google toolbar and MSN toolbar. Another popular paid pop up blocker is at http://ivyliu.com/panicware.htm.
For everyday pop up blockers, the above methods should work. However, if you've tried all of these suggestions and you're still having problems with persistent pop-ups, then it's likely that you have been infected with spyware.
Summary of How to Stop Pop Ups
First, try changing your IE browser settings to block pop ups. If you have Google toolbar or MSN toolbar installed, then you already have a pop up blocker installed along with it. Try using the toolbars, or try switching to the Firefox browser.
Finally, you can also download a pop up blocker (free or paid). It's easy to stop pop ups without having to download pop up blockers.
If these steps do not remove your pop ups, then you may want to download a free or paid pop up blocker.
If that fails, then you probably are infected with spyware, which must be removed in order to get rid of ad pop ups.
But the above four methods should work to stop most pop up windows.
Apr 22, 2013 | Acer Aspire Computers & Internet
Je veux decoder mon telephone de marque motorola w490 t-mobile
Salut, vous pouvez d?bloquer votre mobile par les codes de d?verrouillage et pour les codes, vous pouvez contacter votre fournisseur ou pouvez les obtenir aupr?s de fournisseurs en ligne .. une fois j'ai eu du code de d?verrouillage pour mon portable ? partir mobileunlocksolutions et d?bloqu? mon portable .. vous pouvez aussi essayer de faire partir des codes entre eux et d'obtenir votre d?verrouill? portable .. et avant de d?bloquer votre mobile obtenir id?e claire sur la proc?dure d?verrouillage .. visitez mobileunlockguide pour obtenir des instructions ?tape par ?tape sur le d?verrouillage votre mobile ..
Aug 09, 2011 | Motorola Cell Phones
Code pour debloquer mobil telephone samsung s 5230
Salut, vous pouvez utiliser des codes pour d?bloquer votre mobile. il ya beaucoup de sites en ligne aujourd'hui, de fournir les codes de d?verrouillage. J'ai obtenu les codes de d?verrouillage d'ici
simpleunlocking
pour d?bloquer mon portable.
ici, ils demandent les informations suivantes sur votre mobile
mod?le mobile
pays d'o? vous avez apport? le mobile
fournisseur qui verrouille votre mobile
num?ro IMEI de votre mobile
puis finalement ils vont vous fournir les codes de d?verrouillage d?s que possible.
Jun 26, 2011 | Samsung SGH-S5230 Cell Phone
Continual pop-ups saying OSD Main Control locked followed by language choice, etc. I have tried the buttons on the monitor with no effect
Oct 12, 2009 | Philips 170S5FS 17" LCD Monitor
Computers & Internet Logo
450 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
