Question about Ruud Heating & Cooling
I have a new Rheem water heater that was installed today..it is a 47 gal.
Tonight I begin filling the tub for a bath. At first I mixed cold with the hot...then just the hot. Before the tub filled...the hot water was gone. I called the installing plumber. He came back and checked it. He is baffled. Can you help us?
    Champion:
  • 254 Answers
Check the sensing end of the thermostat. Or check that the thermostat is sensing by checking the m/v output.
Posted on May 30, 2008
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Oct 07, 2012 | Rheem Tankless Hot Water Heater...
How do I fill water heater
Once the hot and cold pipes are connected to water heater, then open bathtub spout on hot side, turn water on so tank begins to fill.
After tub spout is running full stream without air, then water heater is full and it is safe to turn on the heater.
Turning on gas water heater before tank is full can damage tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turning on electric heater before tank is full will burn out elements. Replace elements.
http://waterheatertimer.org/How-it-works.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My electrid rheem hot water heater makes a loud pop sound after using hot water to fill bath tub . Why?
The sound is the water heating through mineral buildup in the bottom of the tank...
The water gets superheated (boiling) because the mineral traps it aroung the element for too long....then it makes the noise as it percolates there....
How to Clean Hot Water Heater
heatman101
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do you set tempature to make the water stay hotter longer? I have a Rheem 82v66 2 (65 gal) and cant fill my bath tub with out running out of hot water.
65 gallon water heater should fill more than 1 bathtub since typical bath only uses 12-14 gallons hot water. First hour delivery on your tank should be greater than 60 gallons.
http://waterheatertimer.org/Hot-water-use-chart.html
Since you have such a small amount of hot water, it sounds like bottom element is burned out, or one of the thermostats is bad. There are two thermostats, and two 4500 Watt elements on 65 gallon tank.
If upper element was burned out, or water heater was not getting 240V electricity, then you would have NO hot water. So we know upper element is good and circuit is good.
Ordinary tank-type electric water heater is fully repairable by homeowner and parts are available at hardware or home center.
I suggest taking 30 minutes and doing troubleshoot before replacing any parts.
Buy cheap multimeter from home center.
When testing voltage, rotate multimeter dial to 240-250-277 VAC
When testing elements or continuity, rotate dial to Ohms.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. I can answer questions as you fix the water heater.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 11, 2011 | Rheem 65 GAL ELEC Water Heater 6YR Self...
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
63 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
