Question about Electrolux Washing Machines
What does E90 message on electrolux EW1280F mean?
5 Suggested Answers
SOURCE: Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Posted on Mar 08, 2008
I found out the hard way that it's because the drain is blocked. Check the filter and even get a torch to look to make sure there is no coin or piece of wire jamming the pump.
Posted on Aug 27, 2008
SOURCE: error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Posted on Feb 15, 2010
  • 42 Answers
Hi Sue
Quite often the manual definition of error code can be quite vague. I would suspect a couple of possibilities. You could have a kink in your outlet pipe, your outlet pump could be faulty or you have a blocked internal or external filter.
Regards,
Posted on Feb 16, 2010
What Does Error Code E90 mean on a John Lewis Washing Machine JLWM1202 made by Electrolux
How should anyone know? Go to the web site and find out so you can be guided accordingly.
Sep 17, 2017 | Electrolux Washing Machines
Electrolux eww1292 washing machine front load problem e90
An E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Oct 15, 2014 | Washing Machines
Frigidaire Atf6700fs2. Machine is giving me message E90. Can someone tell me plz what this means? Ty
The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Read more: http://www.ehow.com/info_12017619_frigidaire-e90-error.html#ixzz2kK4eIkIS
Nov 09, 2013 | Washing Machines
Model ewf1090 electrolux.displays E90 and flashing green lights
its an electrolux fault code.that means .bad connection on communications wire.this is a blue loom of about 5 wires that come off the main pcb and connect to the display board in fascia panel. clean pcb terminals and tighten loom connection pins and this should solve problem"
wd 40 or another type spray should do it........
cheers
Mar 26, 2011 | Washing Machines
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer
Jan 10, 2011 | Washing Machines
Error code E20 electrolux washing machine EW1280F
Feb 04, 2010 | Electrolux Washing Machines
ZWD1471 S E90 ERROR MESSAGE WHAT DOSE IT MEAN ?
E90 means Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides... if still the same fault then main pcb board is replaced 1st tried then the user control pcb is still the same...
Jan 04, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux 1087 E90
what can i do ?
Sep 15, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
