Question about Frigidaire Dryers
There is power to the plug for the dryer but none of the controls on the dryer work and the light in the dryer does not come on. The dryer is about 4-5 yrs old and it was working fine this morning. I checked voltage all the way to the i removable panel where the pigtail attaches. I pulled off the inspection on the back of the dryer and all wires are attached, there is no obvious damage.
  • crevans1 Oct 09, 2010
    How do I get the top off of the dryer to get to the switch? I took out the two screws in the back, but I do not want to force anything by appplying pressure where I shouldn't.
    Figured it out, was actually pretty easy. Jumpered switch and it works so I am on the way to the parts store. Thanks
    President:
  • 1,554 Answers
There is no power getting into the machine. At least the drum light should turn on when the door is opened. The issue here is either the power plug is not making good contacts when plugged in, the power cord is broken, or the door switch is broken. Check the voltages at the terminal block where the power cord connects to then if there are no voltages or if the voltages are not complete (120-120-240 VAC), the problem is either in the power outlet or the power cord/plug. But if the voltages are normal, the problem is the door switch.
Posted on Oct 09, 2010
  • Jahn27
    Jahn27 Oct 09, 2010
    I can probably tell you how if you tell me the exact model number of the dryer.
  • Jahn27
    Jahn27 Oct 09, 2010
    Please do accept the solution then.
WON'T GO ON
There would seem to be a problem with your control board bypassing control selections............service technician required for repairs to this problem.
Nov 12, 2013 | Frigidaire Electric Dryer
Tip
Whirlpool Dryer Various Test Procedures - Part 3
TEST #5 Moisture Sensor
NOTE: This test is started with the machine completely assembled.This test is performed when an automatic cycle
stops too soon, or runs much longer than expected. NOTE: Dryer will shut down automatically after 2-1/2 hours.
The following items are part of this system: Harness/connection, Metal sensor strips, Machine control electronics
1. Activate the diagnostic test mode and advance past saved fault codes.
2. Open the dryer door. If a continuous beep tone is heard and an alphanumeric number is displayed on the console as soon as the door is opened, a short circuit exists in the moisture sensor system. If this doesn’t happen, go to step 3. Otherwise, go to step 4. NOTE: Over drying may be caused by a short circuit in the sensor system.
3. Locate the two metal sensor strips on the inside of the dryer. Bridge these strips with a wet cloth or finger.
If a continuous beep tone is heard and a software revision number is displayed on the console, the sensor passes the test. Go to step 8. If not, continue with step 4.
4. Access the moisture sensor wires: Remove the lint screen. Remove the two wires holding the lint screen to the top. Remove the four screws from bottom of the duct in rear. Remove the duct from the dryer to access
the moisture sensor.Disconnect the sensor connector.
5. Access the machine control electronics. Remove the connector P13 from the circuit board. Check the main
harness connections between the sensor connector and machine control for a short or open circuit. Replace the main harness if necessary. If the harness is okay, continue with step 6.
6. Measure the resistance across the outermost contacts of the sensor connector that includes the two MOVs. Sensor Harness with MOVs (Metal Oxide Varistors) Sensor Connector Sensor Blower Housing Disconnect sensor connector. If a small resistance is measured, check for debris across moisture strips inside of the drum; clean if debris is present. If debris is not present, replace sensor harness with MOVs. Otherwise go to step 7.
7. Measure the resistance across each of the outermost contacts and the center terminal (ground connection).
If a resistance less than infinity is measured, replace the sensor harness with MOVs.
8. If moisture sensor diagnostic test passes, check the thermistor: Perform TEST #4a. If the problem persists after replacing the moisture sensor, harness with MOVs and thermistor, replace the machine control electronics.
TEST #6 Buttons and Indicators
This test is performed when any of the following situations occurs during the Console Buttons and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard
Some buttons do not light indicators None of the indicators light up:
1. See Diagnostic Guide/Before Servicing.
2. Perform TEST #1 to verify supply connections.
3. Perform TEST #2.
4. Visually check that the P5 connector is inserted all the way into the machine control electronics.
5. Visually check the user interface assembly connections.
6. If both visual checks pass, replace the user interface assembly.
7. Plug in dryer or reconnect power.
8. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
9. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
No beep sound is heard:
1. Visually check that the P5 connector is inserted all the way into the machine control electronics. If visual check passes, replace the user interface assembly.
2. Plug in dryer or reconnect power.
3. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
4. If replacing the user interface assembly failed: Unplug dryer or disconnect power. Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
Some buttons do not light indicators:
1. Visually check the user interface assembly connections. If visual check passes, replace the user interface assembly.
3. Perform the Console Buttons and Indicators Diagnostics test to verify repair.
TEST #7 Door Switch
Activate the diagnostic test mode and perform the Door Switch Diagnostic test.
Functionality is verified with a beep each time the door is closed and opened, and a number and letter appears in the display (i.e., 0E, 09). If any of the above conditions are not met: Unplug dryer or disconnect power.
Check that the wires between the door switch and machine control electronics are connected. If the connections are OK, replace the door switch assembly and retest. If the door switch assembly has been replaced and dryer still does not start, replace the machine control electronics.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Samsung dryer dv350ae
follow this steps and fix it. GOd bless you
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front cover to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replace the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace power cord and the terminal block inside the dryer to which the wire is attached.
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control need to replace it or the Timer replace it
Sep 30, 2013 | Dryers
Lights on control panel wont go off
Very likely the unit is fried. Start with a electrical tester and go to town inside the back and the bottom of the machine. Also, before you even do that, check the current at the dryer plug. The two hot wires or for 1) the motor and controls, and for 2) the heating elelent. Then check the wire/cord connection at the rear of the machine with the tester. I've been doing this a long time, and my suspicion would be the timer is toasted. The timer is really sensitive to power surges. If not, do the motor.
Most dryers have a wiring schematic on a piece of paper inside the rear of the control panel to help you pinpoint the problem.
Be blessed.
Jun 20, 2013 | Kenmore Dryers
Control panel not working
If you have power going into the control but it does not illuminate or respond the control will need to be replaced. Here is a link that should help http://appliancehelponline.com/dryerconsole.html These boards are very sensitive to power surges and are not repairable, they must be replaced.
Jul 27, 2010 | Frigidaire FEQ332E Electric Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
175 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
