Question about Zenith Televison & Video
Deflection modual for r50v26 - Zenith Televison & Video
  • Zenith Master
  • 5,138 Answers
UED 1-800-648-6657
Posted on Oct 09, 2010
I am missing my convergence board do they still make them
you may be able to get one from www.tvrepairworld.com they often have or can get discontinued circuit boards.
Oct 17, 2011 | Zenith R50V26 50" Rear Projection...
I have Convergence issue . Can't adjust The allngment crosses on screen no control over the jog button .
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2011 | Zenith R50V26 50" Rear Projection...
How do you manualy adjust them
When you take the cover off the front of the tv (below the screen) you will see a small box with adjustable dials (for a philips-head screw driver) Adjust those dials; there will be one for each color tube (Red, Green and Blue) Slowly adjust while the tv is running to "tweak" the adjustment you are looking for.
Please rate if this helps :)
Mar 08, 2011 | Zenith R50V26 50" Rear Projection...
96 ram 1500 dosent run no fire no feul pump
did you change the modual in your distributor ?
Wires leading to the distributor ...take off cap and rotor ...modual is the one with the wires leading to it ...take out two or three screws ...unplug modual ...un screw modual ...buy new one>>>>>> reinstall
Jan 02, 2010 | 1996 Dodge Ram 1500 Club Cab
I believe I am having convergence problems on top center of unit
The convergence ICs for your set are #STK392-110. You will probably have a burnt resistor as well.
Hope this helps.
Jul 07, 2009 | Zenith R60V26 60" Rear Projection...
Insert toner card? do I have another solution accept new toner?
I believe you are talking about the toner modual.
if you need to change the toner modual, you will need to tell the machine a new one is put in the machine.
Insert the card after you insert the toner modual.
The machine should prompt you that the modual has been installed.
If you have anymore questions about this, please let us know.
May 10, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Replaced toner cartridge and copy had line of toner on edge -
Check the ink modual again.
if the ink is all on the upper and lower lip it needs to be wiped off.
Sometimes when shaking this modual, exessive ink can go on the surface and scrub on the drum itself.
How did you clean the drum?
Nothing should be used except a very soft dry cloth. The toner acts as a lubricant to the cleaning moducal.
Take out the toner modual and see if you can tilt the modual back away so it falls to the back of the modual, this way there will not be so much at the front developer mag roller.
Apr 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
OUR T.V. GOES ON THERE IS SOUND BUT THERE IS NO PICTURE AT ALL AND THE RED STAND BY BUTTON IS BLINKIMG AT ALL TIMES.
what is the make and model of your set? I may be able to help you if you post that information
Mar 22, 2008 | Zenith R50V26 50" Rear Projection...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
