Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
When changing blades do they need to be aligned which each other in any special way. I put new baldes on and they seem extremely noisy.
  • 4,070 Answers
No, they don't have to be aligned. They run off the same belt but can slip independently of each other as they slip when hitting obstacles. New blades might make a different noise because they catch more air then when they are worn. If it's a really loud noise it could be one of the blade shafts wearing. It would have more play in a worn one then one not worn. The usually the one at the discharge chute wears out first.
Posted on Oct 09, 2010
Testimonial: "Thanks for your help."
Rear Tires: Balding
if it has independent rear suspension then have the suspension rubbers checked and replace if necessary. Next for all wheel alignments it is essential that the rear end is aligned first to stop this tyre wear before the front wheels are aligned . IF you have leaf springs at the rear check for axle alignment and broken centre bolts or worn rubbers at the centre bolt mounts.
Mar 24, 2014 | 2003 Buick Rendezvous
How to use the stanley blade disposal to break the blade
You don't. If you have a snap off tip blade you break it outside the container. If you have a razor utility knife you swap blades. the used baldes are disposed of in the container. It does not have any means to break a blade. It is the equivalent of th needle disposal in a doctor's office. The sharps go in the container to keep people from getting cut or stuck. Think of it as a specialized trash can. That's all... (No breaking... Sorry.)
Jan 29, 2014 | Stanley Blade Disposal Containers - blade...
Noisy mower blades
Hi make sure the blades are not hitting each other, also check the blades for marks or paint missing to help you find the contact area. Regards Phil.
Jun 12, 2012 | John Deere Garden
I bought a new balde for hax saw and somehow i get the new balde inn, everytime i tried to tightenning it always lose.
it there is not enough adjustment left to tighten the blade the frame is bent or you have the wrong blade.
Sep 24, 2011 | Stanley Composite Hacksaw
I cannot get my blade back on my A5 Single speed clipper..What am I doing wrong???
The drive arm is probably not aligned with the corresponding opening in the balde. You have to close the blade against the clipper body with the clipper turned on. This should take care of your problem.
Jun 05, 2011 | Oster Golden A5 1-Speed Universal Motor...
How do I put the blades back in my model 059750 005 000 trimmer
I have the same model. Actually, they're quite old. If you don't have replacement blades already, you can find them at Sally Beauty Supply ( sallybeauty.com for a location near you ) for about $20 for this model. The replacement blade may not be available online, but my local store has it available for purchase. You may find it available at your local beauty supply.
Remove the two screws that hold the 2-piece blades in place. Remove the blades and take note of how they are situated together. Both have flat sides that slide together where the teeth meet. Your replacement blades should be arranged in the same manner when you put them back on the trimmer. First place the smaller blade onto the clip. This is best done by aligning one of the diamond shaped hole with one of the flat prongs, then pushing the balde towards the side to help snap the other prong into the other diamond shaped hole. Once this is securely in place put the larger blade on so that the smooth surfaces touch each other and the holes for the screws are lined up. Replace the screws securely but do not tighten it. Do the same with the second screw. You should just barely be able to slide the larger blade around with some effort. You will need to do this to properly align the blades together. The teeth of both blades should never meet at the tip. The smaller blade should be about 1/16 - 1/8 of an inch away from the tip of the larger blade and should be evenly spaced all the way across the width of the blade. If you have this set properly, go ahead and tighten one of the screws. Check the spacing of the blades again to ensure they have not moved. If they have, you just need to slightly loosen the one tight screw and re-adjust. Tighten the screw back down. If all is aligned propperly, you should be able to tighten the second screw without any problems. Don't forget to lubricate the blades with the proper oil. Check you local beauty supply store if you need oil. That's it. They are now ready to trim.
Dec 06, 2010 | Health & Beauty
Baldes are turning when they should not
mine did the same . clean ,check for debris,lubricate all blade engagement parts
Mar 26, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a very noisy front end at above 20 mph.
COULD BE YOUR CV JOINTS. TIRE GUY SHOULD HAVE SPOTTED. CHECK THE RUBBER BOOTS JUST BEHIND THE HUBS. CRACKED? TAKE TO DEALER
Mar 25, 2010 | 2004 Mitsubishi Endeavor
Blade vibrating
Hi, put a new blade on and try it again
If you need more help please write again
Was this solution helpful? Show your Appreciation by rating it:
Nov 14, 2008 | Bosch 4000 - 07 Electric Table Saws
Reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Sep 03, 2008 | Wahl 9765-301
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
493 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
