Question about Nintendo Wii Fit - Balance Board + Game Console
Wii balence board got hit on the top right hand corner with no apparent visual damage but now won't turn on. Light flashes two to three times then stops. Tried to resync several times but does not help. Could a sensor get damaged, if so could I fix it or have it fixed?
    Problem Solver:
  • 16 Answers
Check the board if there are some loose connections that you can fix...
If problem still persist have it check for warranty purposes.
Posted on Oct 09, 2010
My wii balance board is telling me to step off it when I do a body test when I am not stood on it and does not correctly register when I take both feet off the board.
hold down the reset button on the wii then turn it back on, on wii menu hold down the conect button on the wii for 5 seconds then the balence board connector (the connecter button is the red button on both wii products or try new batteries
Dec 20, 2011 | Nintendo Video Game Consoles & Games
Tv will not turn on. The power light flashes red three times as usual when I hit the power button but then it turns itself off without actually displaying a picture. Has been happening on and off for about...
The problem of your television is the power supply.There's a leak capacitor that cause of abnormal voltage output supply.You can identify the leak capacitor through visual checking.The leak capacitor have bulging tops, so replace all the leak capacitor with new capacitor with same value.Remove the back cover and you can see the power supply at the upper right location.Hope it will help you..Thanks..
Sep 04, 2011 | LG Televison & Video
Blue rectangle in lower right hand corner that wont go away
possible bad lcd. bad cof or chip on film. refer local service tech or contact mfg for lcd recall. hopefully its not damage from kids playing wii and one of the hand controls slipped out their hand and hit the screen.
Aug 24, 2011 | Olevia LT37HVS 37 in. LCD HDTV
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
The TV won't turn on. The light in the bottom right hand cornere flashes red and green.
The most common cause of Failure in this unit is power supply failure caused by failed capacitors.
A visual inspection is The easiest way to identify and confirm bad capicitors on the power supply.
Such a capacitor will show one or more of these symptoms:
1) Bulging of the vent on the top of the capacitor. (The 'vent' is the impression stamped in the top of the can. The impression forms the seams of the vent. It is designed so that if the capacitor becomes pressurized it will split at the seams relieving the pressure rather than making it explode.)
2) Sitting crooked on the circuit board as the bottom rubber plug is pushed out.
3) Electrolyte (a crusty brown substance) leaked onto the board from the base of the capacitor
4) Venting from the top of the capacitor, visible as rust-like brown deposits, or a visible hole in the vent
Once the power supply is repaired or replaced your tv should work normally
Jun 24, 2010 | LG 42LC2D 42 in. LCD HDTV
Problem with Hitachi P50H401 Plasma TV - Will not turn on. Blue light flashes 4 times ???? Plasma TV less than 2 years old will not turn on. The blue light continuously flashes 4 times
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
May 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Wii board
Make sure that you have synced the board to the wii (similar to a controller). You have to take the battery cover off the board and push the sync button. The blue light will start flashing. From there you need to open the front cover of your wii under the power button.
From there you start up wii fit and it will prompt you to turn on your board. You should get a solid blue light. If you don't, you may need to try syncing again.
Jan 04, 2010 | Nintendo Wii Fit for Wii
Laptop wont boot
am sorry to say that laptops are more delicate falling from your laps could course alot of damage on the motherboard please visit your nearest service center for help
Dec 15, 2008 | Toshiba Satellite M45-S265 Notebook
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Nintendo Wii Fit - Balance Board + Game Console Logo
113 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
