Question about Ovens
PANASONIC M/WAVE/CONVECTION OVEN. MODEL NUMBER NN-9853. SERIAL NUMBER 5835230320. Number on green side of circuit board (A62606661QP.) Number on brown side of circuit board MS-666. Zeno diode 1 is broken. What are its technical specifications to enable me to identify a replacement part? Cheers Hugh Gibbon
  • hegibbon Oct 09, 2010
    I took the panel
  • hegibbon Oct 21, 2010
    I took the panel & the fractured part to Jaycar at Fyshwick this morning but they were unable to identify which of the multiplicity of zener diodes was appropriate for this application. They advised me to get the specification so they could supply the correct part.
  • Ovens Master
  • 3,083 Answers
I tried my usual "trusty" sites to find a schematic, but to no avail. I read that Panasonic has discontinued support for these, so they're not likely to be of any help unless they could be so kind as to run down the zener for you. Here's what I would do, since you're kind of stuck right now. I would get a 5 v zener of about the same physical size and structure (for current handling capabilities), and try it. If that doesn't produce results, try a 12 volt zener, and see. Most zeners are in those ranges for digital, and if you start off with the lower voltage, you should be able to test out a couple, and hopefully get it going.
Chances are the zener's just stabilizing a 5 volt feed supply, and that would be a good place to start.
Have you tried to get the number from Panasonic's support site online? If you could get a line on their repair center, they would have the schematics and parts lists, and that's what we really need.
The whole problem with this kind of issue, as you may know, is that companies, in general, don't really want you to be able to fix their items on the parts level, and so they make you replace the whole board.
There a site that usually has diagrams, and sometimes schematics, but your model number didn't come up. If you can get a model number close to yours, chances are the zener will be the same. Here's the site:
http://www.appliancepartspros.com/
That's the most likely site to get any help from, and good luck. Here's a link where you can enter a specific question, and hopefully get an answer:
https://secure.opinionlab.com/ccc01/comment_card.asp?width=819&height=614&referer=http%3A//survey.panasonic.com/consumer-electronics/support&time1=1286623962619&time2=1286624008129&custom_var=http%3A//www2.panasonic.com/consumer-electronics/support
Panasonic will have the parts lists, if anyone does, but if they've discontinued support, only facilities that serviced them over the years will still have them. You might try taking a shot at calling around to some repair shops- sometimes you'll find a fellow that will know what you're talking about, and can help.
Good luck, and hope this helps.
Posted on Oct 09, 2010
    Genius:
  • 1,478 Answers
Since you have been able to identify it is the zener diode that is broken, tou can take the panel to any electronic shop to get a replacement zener diode for it.
Take care.
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Door won't. open on frigidare convection oven #240462603 can you help?
Good Afternoon Karen, this you for your question!
I understand your Frigidaire oven (240462603) will not unlock. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
In the meantime, I suggest pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is necessary to wait roughly ten minutes and then turn your range on.
I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck - Z
Mar 30, 2014 | Frigidaire Ovens
Panasonic nn c784mf
Yes, leave the rollers and plate in there.
Mar 12, 2014 | Ovens
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
Good luck :)
May 04, 2011 | Ovens
Where is the serial number on NN-CF778S comi microwave
Hi and welcome to FixYa, I am Kelly
This is from Panasonic:
The serial number is located on the back of the oven or on the door jamb.
To see a picture of the 2 locations for the serial number go to this page"
http://www2.panasonic.com/consumer-electronics/support
click on model # locator near the top of the page in the right column.
Thanks for choosing FixYa,
Kelly
Mar 24, 2011 | Ovens
It shows a code F1
It means the worse. It is the watchdog circuit (tells what the ovens doing at the time) in the ERC (Electronic Range Control) which is the circuit board. It calls to replace both the circuit board and the touchpad. You're looking at about 100 -150 bucks. Sorry.
Jan 28, 2008 | Ovens
Ovens Logo
137 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
