It only fill full the water and after that it does'nt work
  • 176 Answers
Maybe timer or the motor the bilt cubler
Posted on Oct 09, 2010
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
We have a fairly new unit and I hooked up the water line to it and you can get cold water out but it does,nt make ice. I goes through the motions but the water does not fill the tray
You may have a frozen water line or the sensor that shows whether it is filled or not to make ice could have gone bad or may be faulty.
Feb 13, 2015 | Whirlpool Refrigerators
My freezer is working fine but the lower fridge is not getting cold. Recently moved it was'nt sure if i bumped something. Thanks Liam
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 24, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
Does'nt not take the moister out of the air, the fan is on but it does'nt fill up with water
Is the coil cooling? If not it may have leaked the freon out or have a bad compressor. Dehumidfiers work in the same way an air conditioner does to condense moisture out of the air. If the coils don't cool, they will not work.
Jun 26, 2011 | Danby Dehumidifiers
Water gtank full telling me to fill water tank
Hi
Check an see if you have the magnet in your water tank. That is your signal to the computer that it is full if it is at the top of its chamber. If you don't have a magnet ( gray cylinder) in the water tank that is your problem. If it is on the bottom the magnet needs to be replaced.
Jun 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Fill Water Tank But Water Tank is Full
Check the little black rectangular box which is in a plastic channel at the back. To work properly, the rectangular box, with the narrower end facing downwards, needs to be floating at the top of that channel. Apparently it's a magnet which signals the circuitry that the water tank is full. Make sure it's floating to the cap of the channel. If not, you can get a replacement one from Gaggia.
May 29, 2009 | Gaggia Titanium Espresso Machine
I am having a problem with my water well pump ,i bought a new tank for the pump and it still is,nt pumping the water,i took the the pipes up and they were full of water,but the water isn,nt going in the...
did you replace the check valve?
and reprime the pump?
also if the screen at the bottom of the well is plugged you wont get enough volume too fill antthing,and the bladder tank should only run about 2/3 full the pressure on that should be 2 lbs below the pump pressure!!!
if you find that the screen a the bottom of the well is plugged too need too by tablets at the hardware store too put down it cost about 30.00!!
Apr 15, 2009 | Plumbing
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
