Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
Have a battery charger with 2 amp. or 12 amp. setting and switch for maintenance free or alternate type. What do I charge my 21 hp craftman mower at? How long should it take for full charge?
  • 43,501 Answers
Put it on maint. free and 12 amp for about 8 hours and you will be good to go...
heatman101
Posted on Oct 09, 2010
NI-MH D 14.4V 8000mAh Charger Hack. I need an alternative charger like charging on a car battery?
NI-MH batteries a re very different than car batteries and even tho voltage may be similar, you risk destroying your battery, camera or worse, an explosion. Your batter may only need a limited amount of amperage to charge (likely not much more than 1500ma or 1.5 amp) a car battery charger may put out twice or even ten times that much - hence the explosion risk! Also these kind of chargers detect when your battery is full and will quit charging or switch to a maintenance mode. I'm afraid you're pretty much stuck with using the charger meant for it.
May 08, 2016 | Cameras
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Why doesn't craftsman mower tractor yt 3000 charge?
If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
Jul 08, 2014 | Craftsman YT 3000 42" Briggs & Stratton 21...
Battery does not charge on my 15 hp sears rider mower
First thing i would do,check the water level in the battery,don't have to on a " Maintenance Free " battery. Remove both cables,from the battery,clean the cables with a wire brush,especial made for this.There can be a small film of acid oxidation deposit forming,that get into the cable clamps and the battery posts.This causes the cables not to make good contact with the posts. There is something else you can do and that,is use a portable battery charger. Try to charge up the battery with that,this would eliminate the tractor's charging system causing the problem. If this battery won't take a charge or hold a charge,the battery is bad.Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Oct 26, 2012 | Sears Garden
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Battery won't stay chaRGED NO AMPS SHOWING ON AMMETER.CAN BE STARTED BY JUMP AND WILL RUN BUT STOP AND WILL NOT START AGAIN WHATS MY PROBLEM?
it could be a fuw things doing this,,,
check that the engine is charging the battery up when its running,,use a volt meeter across the battery it should show 13.5 volts if its charging up ok,,,,
then check that the voltage regulator is not draining the battery when the engine is not running,,,
fully recharge the battery first then check that it holds this charge,, take off the battery lead and leave the mower for a week or so if the battery has gone flat then you need a new battery!! winter time kills off batterys if there not kept on trickel charge,,,
there's a tip,,,,buy a solar charger,,,and hook it to the battery when your not using the mower,,it will keep the battery toped up for free???
Jun 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
May 30, 2010 | Schumacher & Fast Charge Starter Charger
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
115 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
