Question about Compaq Presario Notebook
Computer wont boot after installing toshiba hard drive
I installed a toshiba hard drive in my compaq notebook and it wont boot
  • tim8406 Jun 01, 2008
    Thank you for the help! i dont know much about computers but im learning ! I appreciate your time
    Scholar:
  • 176 Answers
You need to format and re install the O.S. system to your new harddisk before you can use it . If you installed already an operating system you can check if the booting setup in the bios is set to harddrive boot maybe the booting is set to cd device
Posted on May 30, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
HOW CAN INSTALL XP ON COMPAQ LAPTOP & DISABLE SATA DRIVE ON BIOS
Step 1. Insert the XPsoftware disc. Step 2. Restart your Computer. Step 3. Press F9 when your computer is boot up. Step 4. Change the Boot menu Hard Disc to CD/DVD ROM. Step 5. Press F10 after your change your boot menu. Step 6. Your computer will start to install your XP Software... Thanks Hope successful.....
Aug 22, 2011 | Compaq Presario Notebook
I replaced a hard drive and after loading windows xp, my laptop wont boot, it only gives a hard drive read error.
Remove it then insert again. if the problem as is use another hard drive... also check the set up setting of your unit.
Aug 19, 2010 | HP Compaq Evo n800c Notebook
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
How to install xp 32 bits in compaq presario cq50
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd xp prof. cd.
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk which is for laptop. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
3. or find it from your friend with latest updates requirement. and do from it.
4. Boot from tht cd and start the installation.
5. once it i completed install all video, audio e.tc. drivers.
6. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Compaq Presario Notebook
Replaced hard drive now computer wont boot
If you have a restore CD/DVD that came with your Toshiba, you may have to use it to reformat your hard drive and do a fresh installation. You may have a bad sector or cluster and the boot file is located on it. Try this and check the bios for the setting of your hard disk too. Try starting the system on safe mode by pressing F8 at boot time.
Mar 21, 2009 | Toshiba Satellite® A135-S4467 PC Notebook
No Hard Disc found after crash
Compaq uses F10 at boot to initiate the recovery program resident on the hard drive partition normally called "Recovery". If you cannot initiate the hard drive at boot then press F1 to get to setup and see if the hard drive is recognized there. If it is not then you will have to troubleshoot the hard drive.
If you have another laptop to try the hard drive out or a laptop to IDE hard drive adapter  (cheap) to connect to a desktop computer as a slave drive you will either verify that the hard drive is bad or it is good and a boot sector problem is at hand. Also if you can get the drive recognized as a slave drive you can either rescue data or format the drive.
These are preliminary steps so post again when you have more information. Steve Medley
Jan 26, 2009 | HP Compaq nx6310 Notebook
Compaq Presario V200 wont boot up
Unmountable boot volume means that the computer can't read the hard drive. Which means that either the data on thehard drive is corrupt, or that the hard drive is dead (gone bad).
If you have important data on your computer, there is some disc recovery/maintenance software called SpinRite http://www.grc.com/spinrite.htm It is $89.99 but is really good at recovering data for when the hard drive isn't completely dead.
If the hard drive is still good, but only the data is corrupt, and you don't care about it too much, you can just use the restore discs that came with your computer to re-install the OS (Windows).
Your other option is to buy a new hard drive for your laptop and re-install Windows.
Nov 15, 2007 | Toshiba Satellite A45-S250 Notebook
Compaq Presario Notebook Logo
147 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
