Question about Rancilio Silvia Espresso Machine
I just got a new Rancilio Silvia, it's making a loud knocking noise. Is this common if not what should I do?
  • 352 Answers
The pump is a vibratory pump on rubber mounts. It makes a loud buzz when running.
The pump makes a knocking sound when it is out of place on the mounts and banging into something and when the pressure is high (water flow is blocked)
Open the wand all the way (no back pressure) and make some hot water. If the noise changes to a quiet hum, get a warranty repair. If the noise changes some but is still a knock, take out the water reservoir and the pump shield.
You can see the shield by looking down into the cavity left by the reservoir. One screw hold the shield in place. Remove the screw and the shield, and wiggle the pump around in its mounts until it does not bump into anything when running. Then replace the shield, screw and reservoir.
Posted on Jun 08, 2014
SOURCE: rancilio silvia
It more likely is the automatic boiler shut off if the boiler overheats. Just reset the boiler.
Posted on Nov 08, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Posted on Dec 04, 2007
SOURCE: loud noise
Greetings!
My Silvia was doing something similar to this after no less than 2 weeks of operation.
Not being too worried about the warranty for just opening the case and looking inside......I did so. Be careful. Unplug as you remove various panels. Just don't touch anything with wires. You can see your problem if it is the same that I had.
Remove water res. Remove SS top. To view the pump, I had to remove the SS shield separating the reservoir from the boiler area. You will find the pump attached to the bottom of the chassis. It is supported by a rather flimsy rubber mount. Mine was collapsed to one side.......and the pump was literally banging against the chassis. Yes.....that will rattle your cups sitting atop the machine. To prove that your pump is not held securely in its mount, actuate the ON switch and observe the pump. Use only short burst of power when viewing your pump as you are NOT pushing water thru the assembly....and of course, all those electrical shock hazards that exist.
If it is shaking side to side......that is your problem.
I took a piece of hot water pipe insulation that I had out in the garage and cut it to the length from pump fitting to exterior wall of cabinet. I think that might have been about 4.25 inches (I fixed this problem over two months ago and can't remember the actual length). The insulation piece is very light and holds the pump quite securely in place precluding the side to side vibration and the terrible noise. The split in the insulation allowed for the water line to be held securely as it comes out of the pump.
Reinstall all shielding parts, etc.......and you should be back on your way to minimal pump noise espresso shot pulling!!
All the best........Arch in Virginia Beach
Posted on Apr 13, 2008
mrgrzz
  • 88 Answers
SOURCE: New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Posted on Jan 24, 2009
z34aga
  • 137 Answers
SOURCE: Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Posted on Mar 30, 2009
Machine squeals, Why?
Honestly, no idea, bu you can check user's manual
http://expert-cm.ru/images/stories/shemy_tehnich/tech_silvia.pdf
and watch this tutorial video
How to make cappuccino on the Rancilio Silvia Espresso Machine
Might give you some clue?
Alos, have some interesting information about your machins
CoffeeGeek Rancilio Silvia Espresso Machine
May 19, 2015 | Rancilio Silvia Espresso Machine
What is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
I'm doing the first step, sending a half liter through the machine before making coffee for the first time. The machine makes a very loud buzzing noise. When I put my hands on the upper corners of the...
The loud buzzing is the water pump, sometimes they are loud on the beginning, And the reason is there is no water in the pump. It should get better.
These small espresso machines have a vibration pump (this is the official name), And the name says it all.
Jan 15, 2011 | Rancilio Silvia Espresso Machine
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
I need help with my rancilio
check pump,maybe pump touching body or metal hose make noise
Aug 26, 2008 | Rancilio Silvia Espresso Machine
Rancilio silvia espresso coffee machine
Esprosso Parts http://www.espressoparts.com/ sells all parts for the Rancilio Silvia, including some customized and modified parts.
Mar 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
207 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
