Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
E 13 message on my monitor 2400. What do I do?
  • 674 Answers
E13 means the heater failed to ignite. This could be because of the igniter, the circuit board, a fuel or fuel pump problem, the flame rod being dirty or grounded, The air pressure switch or an overheat occurred. First check the igniter. You can measure the resistance of the igniter with an ohmmeter, it should be somewhere around 16.8 ohms. If you hear a loud ticking or thumping sound before you get the code then you have a fuel flow problem. This can be because of the filter at your barrel or the strainer in the fuel sump or an air bubble in the fuel line. A dirty flame rod can be cleaned with some steelwool or fine grit sandpaper. Unplug the heater before cleaning the flame rod. If the fuel pump ran before you got the error code then the air pressure switch is ok because the fuel pump will not run if the airpressure switch contacts are not closed.
Posted on Oct 09, 2010
No display
check the power light on the monitor.if no then check the power socket.try someother power socket.if this still doesn't show the power light.swap the power cable of monitor and cpu.if this still doesn't lit up this means the monitor is bad and needs replacement.
if the power light is on.
try and disconnect the display cable from the cpu.and if you see some colored box or some message on screen this means the monitor is working fine. if nothing is on the screen then monitor needs to be replaced.
if you see a message on monitor after removing the vga cable then the monitor is ok and issue is with cpu.
reseat the video card if any.
if you don't even see the dell logo then the fault is with monitor.
Oct 30, 2010 | Dell Dimension 2400 PC Desktop
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Aug 17, 2010 | Princeton Digital VL2018W Monitor
My monitor 2400 suddently goes into error 13, I shut the monitor off for a few minutes and then it starts again, it has gone into error for the paste 4 days about 2 tims per day can you give me some idea...
It could be a dirty fuel filter or the small strainer located inside of the heater that is restricting the fuel flow. The problem could also be with the flame rod being dirty or touching the burner ring.
Feb 21, 2010 | Heating & Cooling
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Gmail page too wide
Dear Chuck:
I have a Dell Dimension 2400. Those came standard with a 15 inch monitor. Go to the blank screen, right click and click on properties, then click on settings, your resolution should be set to 1024 by 768. Or click on start, then click on control panel, double click on display, then click on settings, again your resolution should be set to 1024 by 768. If this does not solve your problem, then you need to find the correct video drivers for your monitor and download them.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
969 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
