Question about Kenmore Elite Oasis 27052 Top Load Washer
My washer just started beeping. The panel turned on when I was not washing. I unplugged it and am running the cycle. It seems to be ok, but should I be worried that the electronics are going bad?
  • 347 Answers
Many of these have had this issue. The problem is with the user inner-face board. Most of the time the symptom's you described are all you will have to deal with,other times it will get to the point where you can not select the proper cycle,sooner or later you will have to replace the board but I would try to get as much out of this one as you can.. Good Luck
Posted on Oct 09, 2010
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Ltf2140e
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Kenmore Oasis washer model 110.2709 - Clean washer light is on and machine beeps, after we run the clean washer cycle the light and beep does not clear out. I can't get the washer to run a wash cycle...
Ok this is easy there was a defect on all of them don't worry easy and free fix I want you to call this # (800) 659-7026 they will get your info and send someone out to replace control board. Free. In mean time I want you to unplug washer because it's dc motor it still has juice so hit power then stop tell the lights don't come on plug back in and enjoy the temp fix tell they come out to fix it. Don't worry I sell them and I have one and it is still a great washer it was just the first one out of it's kind so it had flaws but sears is taking care of it's customers.
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washer won't turn on. It just beeps when i
Hi, this is a main control panel issue. here is a procedure you can preform to gain control back.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START.
If the problem persist, you will have to have the control panel repaired by the service tech.
Mar 07, 2009 | Whirlpool WFW9400S
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer won't turn on
try running an extension cord to another outlet (another circuit breaker). ensure the cord is not too long (25 feet ok) and able to carry 15 to 20 amps (use 12 AWG cord).
Sep 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washer flashing fault codes
truthfully, i think you have a malfunctioning board.if all parameters are correct and unit is washing while beeping is taking place. represents board.
May 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
