Question about Regal Ware K813BK La Machine Food Processor
The on button will not push to on. . - Regal Ware K813BK La Machine Food Processor
That is a safety mechanism. Once you put the lid on and slide it to a closed, locked position you'll be able to push the button.
Posted on Oct 30, 2010
Magimix 4200 xl won't turn on
Check that the bit on the lid that activates the switch pushing mechanism in the bowl is working properly.
Aug 27, 2014 | Magimix Food Processors
Kitchen aid food processor blade is not spining neither the motor
Remove bowl completely. Turn motor on and use something plastic to push in the little white button in that is just above the button control panel and normally hidden by the bowl base. If it goes then the problem will be either the working bowl or the lid. There are mechanisms in both that activate that micro switch, they can wear or break. Good luck figuring out which one it is as they are both as likely to be the faulty one.
Jul 15, 2014 | KitchenAid Food Processors
I press a button n it blinks then all the buttons start blinking and the motor never starts.
The motor is most likely open circuit. Solutions are going to be either replace the motor OR if the thermal fuse on the windings is blown you will need to get one of the same value and replace it. The value is written on the fuse and it is under some fibreglass tape on the field winding with the aluminium clip around it. You need to remove the motor completely to do it.
Jan 05, 2014 | Wolfgang Puck Bistro 620 Food Processor
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
It is not working.Not accepting any power and becoming silent.When problem was getting start,its worked a little or once and stop for few hours but now not working completly.
check for the thermal fuse inside non resettable , need a test meter and hand tools about 8-10 dls @ Radio Shack 8 or 10 amp will do or you can install a push button circuit breaker I have no more buying just push the button
Feb 21, 2010 | Braun K 750 CombiMax Food Processor
My food processor light is on but i need to press and hold the black button please help
Use a ball-point pen to depress the button - your finger simply will not do.
This is only to test the motor.
Once it makes the proper sound, you are ready to assemble the workbowl - once properly assembled, the workbowl, lid, and pusher itself will push the button for you. On the DLC-2011, the proper assembly is for the work bowl handle to be locked toward the front of the processor. If you are still having trouble or you have a model other than the DLC-2011, call Cuisinart at 1-800-726-0190 and they will help you with the assembly.
Aug 18, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Bravetti Chopper Model FP 105H
Not positive as to your problem, but I was just given one of these and thought it didn't work. On closer inspection, I found a little switch that needs to be depressed from the bottom side. When I pressed it with a tiny screwdriver while holding down the bar on top, the motor runs!
I just have the white top with the motor and the glass jar thing. So I'm on a search for whatever is supposed to fit between them. There's room for a seal between the two, and I imagine it has something to push the tiny button, to activate the motor (guess technically it's a safety interlock).
In case it isn't obvious where that button is, turn the motorized plastic top upside down and look at the center. There's the star drive in the middle, and four little depressions, or holes around it. One of them isn't white inside. It's the magic switch! When I push it with a screwdriver and push the power bar, the thing comes to life...
If that works it for you, then your new mission is to figure out what pushes that button and put it in the right place.
Oct 21, 2008 | Bravetti SB212H Quad Blade Food Processor
Food Processors Logo
107 people viewed this question
Top Regal Ware Food Processors Experts
Henry  Thomas
Henry Thomas
Are you a Regal Ware Food Processor Expert? Answer questions, earn points and help others
