Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101
I would love to give specific advise for your dryer but you have not included a model number or type gas or electric...
here is the answer that I give for all the freebies that gives tips that answer your question for both the gas and the electric dryers...
The chances are very high that the ignitor has gone bad....they are very fragile and go bad at any time. They can even be bad when they still light...read the gas dryer no heat tip it will explain things further for you...
Here is the part that you need from the repairclinic site...
http://www.repairclinic.com/Igniter-Part...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
Amana Gas Dryer
Model # LG4309W
Serial # 9301036038
Sorry I omitted. Please respond again if possible. Thank you.
Amana Gas Dryer
Model #LG4309W
Serial # 9301036038
Sorry I omitted this initially. Please respond.
