Question about ASUS Eee 4G Notebook
New purchase hi, i'm about to purchase a and noticed that there are 2 with the same SKU with the exceptio9n of an 'x' at the end... anyway, which will be better for me to run salon software on... this will be the main purpose and also how can i upload the program when there isnt a dvd/cd dock?
    Scholar:
  • 139 Answers
The model doesnt matter at all from what u have just said they both will work well now yu dont have cd/dvd dock i think they should be an option for flash drives so u can work thrugh that .
thank u
Posted on May 30, 2008
I purchased new laptop model AL101,i found there is no CD drive can you please advise
The easiest solution would be to purchase a USB CD/DVD drive. I would recommend the following: https://www.bhphotovideo.com/bnh/controller/home?O=&sku=1077752&gclid=Cj0KEQiAhZPDBRCz642XqYOCpb8BEiQANUcwT_pCsdBOTtrebfdAqUqgUX5EBkZH490b4yezPV-NHzAaAv8i8P8HAQ&is=REG&ap=y&c3api=1876%2C52934714882%2C&Q=&A=details
Dec 29, 2016 | Computers & Internet
Foward controls
WOW!
The last of the right hand shifts!
Anyways, for example, let's talk about something like this:
https://www.denniskirk.com/medialibrary/viewer.jsp?mediaType=altImage&sku=575621
Remove stock brake pedal arm, and shifter arm.
The plates on the end attach to the front motor mounts, picking up the existing attachments.
Attach included ends to the remaining brake cross-over shaft, and the shifter shaft.
Adjust as needed.
Test ride.
Dec 03, 2013 | Harley Davidson XLH 1000 Sportster...
Hi, one of the audio phono leads has packed up on my Technics 1210 after all these years. Have cut off the actual input jack (white) and was wondering how best to go about adding a new one. I thought this...
Hi, Replacing the rca plug at the end of the cable is just a matter of splicing the wires correctly. The wire is actually a 2 wire line, almost directly under the black outer casing will be the ground wire ( is actually going to be totally wrapped around the center wire ) this will be evident if you look at the cross section where you cut the cord. The replacement end can be purchased at the local Radio Shack, less than $3 probably for a pack of 2. When stripping the casing from the cord be carful not to cut away too much of ground wire sheath ( this may lead to difficulty in attaching new end ) it is almost inevitable to have a few strands of wire cut loose. The next step is to sort of " part " the outer sheathing, then kind of wrap both halves around the inner conductor as close to where you stripped outer sheathing away as possible. Next strip away the inner wires sheathing and you have the two ends to either solder, if you know how to, or tie through the holes of the replacement rca plugs leads. I hope this was of enough help and thank you for asking FixYa, Good luck-Prodzilla
Apr 16, 2011 | Technics SL-1210 Turntable
Need widows 7 driver
Hi gene12303 !
Here is a link for the Vista driver. It should work with Windows 7 too.
http://webprd1.3com.com/swd/jsp/user/index.jsp?id=3CRDAG8
Best of luck,
omerk.
Jan 29, 2011 | 3Com 3CRDAG675B Wireless LAN PCI Adapter
Hi, I have this type of printer and there has been no problems..except.. i'm the new secretary and the golden drum light is on..never noticed if it was or has been always on..and the printing every 1 1/2...
Means toner cartridge is nearly to end. Just shake a little bit to distribute evenly the toner powder and be ready to purchase new toner cartridge. And is it nothing to do with the drum. Drum problem will create black shadow lines when printing.
Dec 07, 2010 | Brother HL 1440 Laser Printer
Manual for 1024501 gilson tiller Have no info on it ,would like sku matics of parts and ref #s
In the 80's, Gilson was bought by Lawn-Boy,
In the 90's, Lawn-Boy was bought by TORO.
At the end of 2009, Toro will discontinue Lawn-Boy.
Gilson parts and manuals did NOT transfer with the Lawn-Boy to TORO purchase. Gilson is NLA, sorry.
Nov 07, 2009 | Garden
Electronic Low Voltage Master Dimmer
Home Depot sells Lutron dimmers which are single pole and basic.. www.homedepot.com
Apr 24, 2009 | Lutron Electronic Low-Voltage...
PSP
http://www.dealextreme.com/details.dx/sku.3217
if they are both the fat (old) PSP
http://www.dealextreme.com/details.dx/sku.12884
if it the slim (new) PSP
take the PSP apart (careful 2 screws are hidden uncer the bottom sticker in the batt. compartment.
use a flat screw driver and pry the broken screen out
pull the 2 flaps on the connectors of the flat and wide rib.
lift the screen out.
put the new one in connect all the connections first
snap the scren in
reassemble.
done
please rate
please rate
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
