Question about Maytag Dishwashers
Maytag dishwasher model #8859 where the control panel is on the top edge of the door, should the control panel be visible when the door is closed?
  • 58 Answers
If you are talking about the integrated control design on the top of the d/w door panel then no. They are designed to fit tight underneath the counter top for a better look.
Posted on Oct 09, 2010
Maytag load sensing technology
The way that you can troubleshoot this: Turn off the power to the machine with the breaker or if you can reach the plug and it is a plug (and not wired direct) and wait a couple minutes and turn it back on and see if that resets it. If it does not, Take the six screws that are in the lid on the top edge. There are two on each side and two in the middle near the latch. You should then be able to remove the control panel. IT has lots of wires connected to it. There is a module on the right side that has lots of wires connected to it and there is one ribbon cable that connects to it that is also connected to the control panel. UNPLUG that ribbon cable. Put the control panel back on, leave the door open and turn the power back on. Then close the door, if the pump starts and you hear it draining then the problem is in the control panel, if the pump does not start then the control board is bad. Both parts are about 160 dollars. You can also enter a diagnostic mode to test things by pressing HEATED DRY, NORMAL, HEATED DRY, NORMAL and it should light all the lights and if the door is closed then it will start all the tests.
May 21, 2013 | Maytag Dishwashers
Tip
How to get help so you can fix you own appliance
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your model number is needed in order for someone to help with the diagnosis or your appliance. There are lots of different parts and each model is different. Post this number in the description of your problem and you'll be much more likely to receive the help you need .
It's usually stamped on a small tag in a visible location on your appliance.
On your refrigerator look
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
On your oven look Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer
behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher-
Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave-
on the face frame behind the door or on the back.
on Jan 31, 2010 | Dishwashers
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Need an schematic for model fdb435rfr
A paper brochure with schematics, parts list and service diagnostics was inserted behind the control panel at the factory in mine. To get it out, shut off power at the breaker box; lay the door down horizontally; unscrew the two screws (now facing up) in the door that hold the ends of the control panel to the interior edge of the door. (You may also have to unscrew any along the top edge.) The control panel will drop away from the exterior of the door. The paperwork will be under a clip near the controls.
Jan 11, 2011 | Frigidaire 24 in. FDB435RFR Built-in...
Upper rack axle for kenmore elite
Your model number is needed for more information.
Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Kenmore Dishwashers
Replace top burner outer coil not heating
Hi- There are a few on either side of the control panel assembly, under the covers. They like to hide them. Some models have connectors for the wiring harness to top, so you can remove whole assy. to work on it. Helps to have somebody hold top while plugging/unplugging though. Pay close attention to which wires go where when replacing element.  Let me know if this info helps- have more if ya get stuck! Thanks- Ed
Mar 18, 2010 | Maytag Gemini 30" Self-Cleaning...
My Maytag MDB9150AWS is no longer working due to what I believe is a electrical fire in the front control panel as there was smoke coming out of the top of the front panel. There were no flames but the...
My dishwasher (same make and model) had a similar problem except I did see some sparks coming out from th front on the side of it (on Thanksgiving Day no less - a lot of manual diswahing followed). What the problem ultimatly was is what I believe to be a factory defect. On the front door if you remove the inside panel to expose the wiring, I found where the door closes, the ruber coating on the bottom metal edge was worn away (from just years of opening and closing the door. There is a bunch of wires that run from the control panel to the power source and pump. Once the metal was exposed it comes in contact with these wires when the door is opened and closed and it was just a matter of time before they got shorted out. Fortunatly for me this happened while I was standing right there and was able to turn it off or this may have resulted in a fire. Also because of the quick shut off, none of the electronics or motors seemed to be affected. After respliceing the wires that were exposed, the dishwasher is working as normal. I plan to go back to Maytag to see if there is any complaints regarding this same issue.
Nov 03, 2009 | Dishwashers
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Makes growling noise during the wash cycle. some vibration. unit is 6 or 7 years old. it is a maytag jet II EQ. cannot locate the model number as it is a built in unit. would appreciate any help. thank you
Hi Spacepaint, No manufacturer hides the model/serial number behind the enclosure. Look closely on the side of the door panel edge and on the inside edge of the door jam. You will find the model number there.
Growling that happens on every cycle normaly indicates either debris in the sump area / filter or a failing pump motor. Remove screws and inspect the well area for debris.
Recommend a service call if problem is not resolved by the cleaning.
Mar 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
KitchenAid model KUDS25SH (Stainless) latch has come loose.
Remove the six or seven screws that secure the entire control panel to the door (screws are located inside of door around the top. Pull out the control panel and the door latch mechanism will be right there for you to work on.
Jan 31, 2009 | KitchenAid KUDC25CH Dishwasher
Dishwashers Logo
78 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
