Question about Refrigerators
How do I turn off my Kolpak walk-in freezer? Cooler? I have empties them both and I will not be using either of them for 3 months. Please help!
  • Refrigerators Master
  • 1,238 Answers
No special procedure. just kill them at the breakers.
Posted on Oct 09, 2010
Kolpak walk in freezer . the door heater will not work
Suggest replace the element.
Since this is an electrical/safety issue also suggest have qualified personnel attend to it.
Nov 02, 2017 | Kolpak Refrigerators
Looking for a manual on my kolpak model 38823s walkin cooler freezer. Or a web site
http://www.kolpak.com/search.aspx?searchmode=anyword&searchtext=38823S
Try the resource center. I found a few manuals but this site is not very user friendly. Have to kinda surf around.
Aug 10, 2017 | Kolpak Freezers
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
1999 kolpak walkin freezer not staying cold
Is the compressor cycling on and off? Is there any oil around fittings at components? Gas is the last thing you put in a refrigeration system. You need to find the leak before you put any more gas in the system. Hope this helps good luck.
Apr 08, 2014 | Kolpak Freezers
On the ceiling in the walk-in freezer drops of water frozen around the area by the fans
That tells me that when the evaporator defrost the water condensate is not draining to the outside of your freezer. You will need to find the drain blockage, Thanks Sea Breeze
Feb 27, 2013 | Kolpak Commercial Freezer
On the ceiling in walk-in freezer around the fan area drops of water frozen
Generally that is just frozen water vapor left over from the defrost and nothing to worry about. hope this helps and good luck.
Water cooled walk in Refrigeration not cooling and compressor and condensor fan turning not turning on
if u live near madison wi i charge u $55 to check what it is wrong
if fan work. the relay is bad
Jan 13, 2011 | Kolpak KOL-P6810CS Walk In Cooler Polar...
Kolpak walk-in hinge adjustment
I have a similar problem. Mine is due to the plastic hardware in the hinge being worn down.  The temporary fix has been to disassemble the hinges and pull out the top and bottom "slanted plastic-gravity-activated thingies"  These cause the door to close from the action of gravity and the weight of the door. These plug into the hinge on the refrigerator shell and look like a 3/8" hex-key. Once you have removed those inspect them for wear.  If your problem is anything like mine, not only has the door started to rub against the floor but the spring-activated door closer seems to be out of alignment too.  This is because the plastic on the "slanted plastic-gravity-activated thingies" have worn out and in-as-such with every open and close the door has made a slow and steady journey to being closer to the floor.  While you're waiting for a Kolpak rep to get back to you or what-have-you a temporary solution is to find two small nuts of equal size and drop them into each of the holes where your s.p.g.a.t plug in.  (Be sure sure that they're small enough to get back out!  On my first try I threw in a few small washers that didn't quite fit and it took some growling and maneuvering with needle-nose pliers to get them back out.)
To say nothing of the two-person-job of getting the hinges and screws lined up, you can now reassemble the door and ignore the problem until the s.p.g.a.t. wear down further or your Kolpak rep finally gets back to you...whichever takes longer really (I kid..I kid -- they're alright.)
Jan 09, 2009 | Kolpak WARRANTY-3/4HP 5 Year Walk-In...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
