Question about Whirlpool Washing Machines
Hi... I have a problem with my whirlpool duet washer... The past few months its starting to smell and as the days go by its getting worse... I have checked the trap for cloths getting stuck, which do happen sometimes and I have also had all the pipes cleaned out... Could there be a small piece of cloths, like a sock **** behind the drum or Could there is water lying somewhere that is not getting drained... Please tell me what could be wrong. Thank You lifesaver104@hotmail.com
Affresh tables is the only thing I know of that will work for you you can find them at amazon.com or http://www.affresh.com/ It is designed for this very problem hope that helps.
Posted on May 30, 2008
  • kris10smith May 30, 2008
    OH p.s. oder in front loaders is common your not the only one :)
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet Washer has an extreme mold smell. I have
The mouldy smell.......what else?
try adding 2 or 2 cups of Sugar Soap Concentrate then fill the machine and leave it for 24 hrs.
Then put it through a wash cycle without any clothes.
If this fails to fix the problem you are looking at a complete strip down and clean out!
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Strange smelling towels - HE Frontloader
Try running the washer with detergent and a box of baking soda--no clothes--and HOT water. Do you have very hard water in your area?
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
Make sure the door is kept open when not in use and also make shure that you do the cleaning procedure as described on the book once a month.
May 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
