Question about RCA Televison & Video
We can not locate the convergence on our RCA HDTV remote?
    Genius:
  • 1,030 Answers
What is the model 0f television. customer covergence options are in the setup menu. how does the piture look? under customer option setu menu do you have the covergence option? tell me and i will see if i can help
Posted on Oct 09, 2010
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA hd52w59. I just got it today used and I don't have a remote for it. The colors wont converge and I think it is a Convergence Chip Failure from what I have read on here. But one of the ways...
chek to see is the setup menu has the word convergence on page.
if not the the problem is an open 0.4 fuse beside the flyback/center one of three in a row.
the fuse blows because the flyback need to be resolderd, cracks on pins.
Mar 24, 2011 | RCA HD52W59 HDTV Projection Television
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair
World.com,Tv Repair kits.U know how to solder right?
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
Convergence
I'm assume you are referring to a non adjustable convergence option. this will occur when you have a damaged convergence chip set that is located on either the PC board or the convergence board. The location of the affected chip will vary from model to model but, in most units, this can be fixed by replacing the convergence board or chip.
May 31, 2009 | RCA HD61W66 61" Projection HDTV
52 inch rca look like 3d picture
You have a convergence problem. The Red and Blue are out of convergence meaning they are out of synch, causing shadows. There should be an Auto convergence option either on the television or through the menu options on the remote. If this doesn't fix your problem, then there's a manual convergence option. Should that fail, a service call is in order. Best of luck!
Greg
May 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA CONVERGENT PROBLOM
The convergence problem is likely to be in the convergence power supply which is located above and between the two boards which lie flat inside the chassis. The power supply has a chip on it which is a common problem (If it is not the transistor type then change the whole board.) part number on the chip where the metal heat sink is located. Part number may be STK 730-010 or STK 730-130 both number will work and must be unsoldered and new soldered in.
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
