Question about Nissin Di866 Flash for Canon
Dropped my Nissin D1866 Flash . Broke the plastic guide for the hot shoe. Where can I get it repaired
3 Suggested Answers
SOURCE: Hot shoe plastic section broke on flash unit
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Posted on Feb 15, 2011
  • 254 Answers
SOURCE: Can the shoe be replaced on a Nissin Di622?
Yes, it can be replaced by me.
Canon or Nikon versions?
Posted on Oct 04, 2012
Repair a broken hot shoe mount on the speedlight
Have to try tighten down the four screws holding the shoe?
Would you like me to fix it for you?
If it is just the Hotshoe Assy, then you can buy from me.
They come in two versions:
Nissin Di866
Nissin Di866 Mark II
Are you from USA?
Truly,
atdlee@netzero.com
Aug 12, 2014 | Nissin Di866 Digital Flash TTL for Nikon...
Canon eos 1000d flash not working
To the left and the right of the hot shoe (where your speed light slides) are two rails. On the end are two springs. `one is connected to a switch indicating there is an external speed light connected.
If on is kept in place the spring will keep telling I have an external speed light. Check what spring is not back in the correct position.
Look from the backside to the front.
Mar 20, 2014 | Cameras
Sep 14, 2012 | Nissin Speedlite Di622 TTL Flash for Canon
I have broke my hot shoe nissin (DI 622) where can i get replacement of the hot shoe....
I have broke my hot shoe (the contact piece that slides into the camera) is there a way to just replace that piece
Apr 28, 2011 | Nissin Cameras
I have a Di622 Nissin Flash, the base is broken. The part that slides into the hot-shoe. Would like a quote on the fix.
i have a Di622 Nissin Flash, the base (hotshoe contact piece that slides in camera) is broke is there anywhere I can order the replacement piece?
Jul 20, 2010 | Nissin Speedlite Di622 TTL Flash for Canon
Hope this helps!
Jun 17, 2009 | Sony HVL-F32X TTL Flash
Canon 430 flash
the best will be to take the flash to a canon repair center
you can try to repair it yourself, you will need a peace like this:
http://cgi.ebay.com/CANON-420EX-430EX-580EX-HOT-SHOE-FOOT-LOWEST-INTL-SHIP_W0QQitemZ370071354531QQcmdZViewItem?_trksid=p3286.m20.l1116
Sep 09, 2008 | Canon Speedlite 430EX TTL Flash
Broken Hot Shoe
This link gives step-by-step instructions with pictures for replacing the shoe.
http://planetneil.com/tangents/2007/05/31/repairing-the-canon-580ex-hotshoe-foot/
Jun 16, 2008 | Canon SPEEDLITE 580EX TTL Flash
Replacement shoe for Sigma EF-500
I had the same thing happen. Sent it into Sigma, they replaced it for 50 bucks.
Feb 03, 2008 | Cameras
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Nissin Di866 Flash for Canon Logo
277 people viewed this question
Top Nissin Cameras Experts
jc21680
Level 1 Expert
Richard McGrath
Level 1 Expert
Tom Chichester
Are you a Nissin Camera Expert? Answer questions, earn points and help others
