Question about Sunbeam 2386 MixMaster Series Stand Mixer
I was mixing some butter, sugar, and peanut butter when the mixer suddenly sparked a little by the beaters and then stopped working. There is a plastic/metallic smell and it won't turn on anymore. Help?
    Champion:
  • 248 Answers
Burnt motor ,not safe do not use
Posted on Oct 09, 2010
Mixer Kenwood Chef too high, tried adj screw
I put an extra plastic circle in the base of my machine as well as doing the adjustment and it worked.
May 29, 2016 | Kenwood Food Mixers
Hi my mixer suddenly stopped when i was working on it. The butter i was beating was kinda hard is that a reason it stopped?
could well be why it quit .supposed to use room temp or little warmer possibly striped the gears inside
Apr 16, 2015 | Food Mixers
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
Motors continue to go out. No notice or anything, just stops. Bake cookies, butter, sugar and flour only, not a heavy dough. Normally lasts for about 9 months. I always make sure butter is room...
When you say that the "motor's continue to go out," do you mean that the motor itself stops working or that the motor still runs but the beater stops turning? These are two different problems.
Take a look at this Service Manual which is correct for your model and see if it helps:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jan 23, 2018 | KitchenAid K5AWH Stand Mixer
I just got my mixer a few weeks ago for Christmas. I have made cookies twice. My problem is that the bottom of the bowl doesn't get scraped. The first time, I ended up putting more flour in the dough...
Put the flat beater on and mount the bowl to the machine. Now look for the screw next to where the beater mounts on the head- this is the adjusting screw. Turn it counterclockwise to lower the beater, just a quarter of a turn, and then check where it's running in the bowl. Repeat as necessary. If you need to raise the beater, just turn the screw the other way.
lp
Jan 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
My handmixer suddenly stopped working while i was
sounds like the beater is not all the way in or it broke a gear
Mar 12, 2009 | Braun M880 MultiMix Hand Mixer
Mixer not creaming butter and sugar...
make sure you are using the right attachment. usually for batters you want to use the flat beater. not the dough hook. the flat beater looks like a triangle with lines through the center. and make sure you are using the correct speed on the mixer. start out at stir and then go up to no more than half speed. these mixers take a little longer to incorperate batters but they do a very good job at it. if the batter is thin enough you can try using the wisk as well. but only if it is a thin batter.
Apr 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Sunbeam 2386 MixMaster Series Stand Mixer Logo
257 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
