Question about Philips Magnavox 15MF400T 15 in. LCD Television
How do you repair the or check the Back lamp?
Hi Jerry,
I noticed that I have sound but no picture, but i do see a faint picture when I flash a light on the screen. So I was wondering how I would repair or replace the back plane lighting? Thanks for any help
  • Philips Master
  • 1,689 Answers
This is not something you should do yourself unless you are experienced at doing this type of service.
If you call the parts supplier for the manufacture of your set, you have to find out the part numbers for the backpane lamp and power supply for them.
Some sets use 2 sets of lamps and power supplies together, or a common supply for multiple lamps. This is model and design dependent.
In some models the lamps are not able to be replaced. They replace the complete screen assembly.
In some models of screens, the complete screen assembly must be taken apart like a wafer system. Taking the screen apart is not too bad. It is getting it back together, and having the lamps installed to not give shading errors.
You will most likely have to undo a number of ribbon cables. If the cables are heat sealed to the circuit board, they will have to be replaced, and re-sealed back on. If the ribbon cables are on connectors, then this will be easier.
My suggestion is to give the set to the Philips service rep to evaluate and replace the lamp system if it is feasible or able to be done. If they make an error or accidentally damage something, they will be responsible. When they do the work they should warranty their job.
Jerry G.
Posted on May 31, 2008
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Flashing red light no picture and a buzzing sound
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jul 24, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
Sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
Jun 06, 2012 | Televison & Video
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Very faint picture- no sound
If the red lamp light is blinking the lamp is probably shot. The pricing of the lamp varies from $200 and up plus installation. Or you can buy the lamp and install yourself. See the owners manual on instructions to replace the lamp.
Nov 17, 2007 | Sony KDF-E55A20 55 in. LCD Television
Philips Magnavox 15MF400T 15 in. LCD Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
