My function key wont turn off - Computers & Internet
Why does my laptop not allow me to move my cursor?
might be a function key possibly f5 on my toshiba turns off mouse may be a different function key on Asus that does this.
otherwise lock up try ctrl Alt Del keys see if task manager option comes up. if it does one application may be locking up p.c.
Sep 10, 2016 | ASUS Computers & Internet
How to use function buttons'
select the F key that shows the LCD icon, mine is F5 but maybe different for your make and model. Once you have located it press Fn key and hold, and press the F key you have selected, this should turn on the laptop LCD screen.
Mar 21, 2012 | Lenovo IdeaPad Y560 Notebook
Screen wont turn on at all. machine sounds like its running but no power to the screen. i tried the vga conection and hooked it up to a monitor but still no picture.
There may be a key combination that turns the external VGA adapter on. This may be something like FUNCTION + F4. Have a look at your Function keys and see if there is an image like a screen or laptop on it. Pressing and holding the FUNCTION key then pressing the screen key will let you enable the LCD screen, the VGA, or both.
Jul 27, 2011 | Toshiba Computers & Internet
My ti-89 keep repeating the same function ! no matter what i click, it came out the same function. The only way I can do is take out the battery. Otherwise, it just keep showing me the fame function.It...
If the calculator keeps showing you the same function, you can open the Y= editor and erase the function. To turn calculator OFF, press Diamond key then ON.
Feb 19, 2010 | Texas Instruments TI-89 Calculator
Caddy Deville wont start
Check the gear selector switch. You may need a Chilton's book to find it. Try starting in neutral.
May 04, 2009 | Dell Inspiron 2650 Notebook
Screen wont come on
no "lock" button but there is a function button to switch the primary monitor from the built in one to an external one. on the lower left han side of the keyboard there is a key labled "function" hold that down and look along the top row of buttons (f keys) one of them has a green or blue picture of two monitors, with the power turned on try holding the function bution and the f key and see if it comes back on. also there is a brightness key as well make sure it is all the way up.
Not to discourage you but I just sent back 4 of these same models to acer for warranty for the exact same problem. All four of them however did work with an external monitor.
Dec 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
The fn key is working,but it wont t4urn off. how do I get it t6 turn off?
Function ket is a toggle key.
press the function key once, enable press again, disble.
Dec 01, 2008 | Averatec 3200 Notebook
KEYS AND MOUSE
Check to make sure your touch pad is not turned off. Regarding the keyboard you need to check to see if you have set the laptop to work off an external keyboard. Check the function keys at the top of the keyboard they are used to turn on and off the keyboard and mouse functions
Sep 07, 2008 | Acer Aspire 5100 Notebook
Ignition barrel
Tried turning the wheel a little to disengage the lock function?
Jul 07, 2008 | 1989 Nissan Pulsar
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
