Question about Braun 8585 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very rarely cleans and lights as clean most times. Is this a shaver problem or a base unit problem? What is the fix?
  • Braun Master
  • 1,602 Answers
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Posted on Oct 09, 2010
Make my own cleaning solution for my braun shaver 8585.
It is just an alcohol solution with a very small amount of cleaning solution. A jewelry cleaner premixed would do it.
Nov 20, 2014 | Braun 8585 Electric Shaver
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Sep 15, 2013 | Braun 8585 Electric Shaver
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
Sep 25, 2010 | Braun Health & Beauty
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
Nov 25, 2008 | Braun 8585 Electric Shaver
Braun 8585 charger cleaner - not cleaning
you can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
Nov 10, 2008 | Braun 8585 Electric Shaver
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun 8585 Electric Shaver Logo
377 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
