Question about Canon EOS-20D Body only Digital Camera
Camera will not turn on
The battery has been dead for quite a while but I finally charged it up but the camera is not coming on. Please help!!
    Scholar:
  • 51 Answers
It could be that the battery itself is dead and is not accepting a charge. Try another battery, if not Try recharging it again overnight.
If a replacment battery still does not work there may be a fault with the camera. Make sure all the conectors in ths battery compartment are clean. If the camera was stored for a long time with the battery still in place you may need to take it in to a Canon dealer.
Hope that helps
Posted on Jul 15, 2008
Gopro charging problems flashing
GoPro battery dead. Won't charge in the camera. No charge light comes on when you connect the camera to a USB. There's the scenario. Good tip on the GoPro battery shocking technique posted by Rabscuttle above. I discovered that my vehicle USB cigarette lighter adapter drains the GoPro battery when it's turned off. With the GoPro battery completely dead, the camera will not charge it. If the GoPro battery voltage falls below a certain point, the camera's circuitry is set to turn off the internal charger as if there's no battery in the camera at all. The recommended solution is to buy an external charger, which is able to charge a completely dead battery. The battery shocking method saves that expense.
Connecting a 9 volt battery to the GoPro battery for 30 seconds can give the battery enough charge to allow the camera to recognize the battery. A 9 volt battery from a smoke detector, a pair of jumper leads, and two straight pins is what I used to get my GoPro battery charged enough to allow the camera to recognize the battery and begin charging.
battery_zps064fc8f6.jpg?t=1415296281
img_2564_zpse9e14b4e.jpg?t=1415296297
May 30, 2012 | GoPro Cameras
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
The light doesn't come on when the charger is plugged in to the camera, therefore I am unable to charge the battery and turn the camera on. Does this mean the battery is dead?
When the light does not come on while charging as you suggested might be the battery is dead but even when batteries die the indicator foe charging still comes on.
From a professional point of view i would say it is more likely the charger is spoilt this means the camera does not supply power to the unit.
Hope this solution has been helpful?
Nov 29, 2010 | Nikon Coolpix 3200 Digital Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Camera dont come on
The battery or the camera itself may be faulty, take the camera back if you bought it new
kind regards and please don't forget to rate us
Dec 08, 2008 | Jazz DV-179 Digital Camera
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Camera just won't turn on!! :)
Katie take it back to where you got it places like best but some time will just give you another camera no questions asked.
Apr 19, 2008 | Samsung Digimax L730 Digital Camera
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
Canon EOS-20D Body only Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
