Question about Galaxy Radios DX-929 40-Channels Base CB Radio
Got a used 929 from a friend. it worked for about 2 min then went dead. No lights needle dosent move when keyed. It does make a soft whamp sound when turning it on. any ideas? thanks
    Novelist:
  • 500 Answers
The board may have loose connection on the voltage regulator.. if not may have blown the protection diode. IF you need help let me know.
Posted on Jan 03, 2011
I have TFDVD 3299 and sound just went dead, how do I get it back on
2007 Chevy Silverado can be driving down the road and ...
www.fixya.com/.../t26047925-2007_chevy_silverado_driving_down_ro...
33 mins ago - Sounds like your fuel filter need's to be changed. Start with .... I haveTFDVD 3299 and sound just went dead, how do I get it back on. Jan 10 ...
I changed the batteries now I can get anything to work. The ...
www.fixya.com/.../t26047899-changed_batteries_now_get_anything_w...
47 mins ago - 2000 lincoln continental car will not start, acts as if battery is dead, but ... I have TFDVD 3299 and sound just went dead, how do I get it back on.
Where is the fuel pump reset button? - Fixya
www.fixya.com/cars/t26047883-fuel_pump_reset_button
59 mins ago - I have TFDVD 3299 and sound just went dead, how do I get it back on ... Will only run for 13 minutes then exhaust light comes on then engine ...
Jan 10, 2016 | Cars & Trucks
Receives fine, needle does not move on transmit, transmit light lights
Needle on the meter might have went out . Is it stuck in one spot? If it moves during receive and goes to zero when keyed it most likely the final.
Mar 08, 2015 | Radio Communications
2004 mini cooper doesn't start
Most likely a bad battery or battery terminal connection.
Apr 19, 2017 | 2004 Mini Cooper
When i unlocked my car with the remote the car went dead. the anti-thief device engaged. how do i disarm it?
you will have to take the fuse out of the brain of the antitheft system if its an aftermarket system if its not then you will have to unplug the battery for about 5 mins then hook it back up if that dosent work you will have to manually lock and unlock the vehicle with the key instead.
Jan 30, 2010 | 1998 Dodge Caravan
Speedometer
look closly at the needle, there is a pin that the spedo needle sits on when the vechile is not moving. it normally sits on the top of it.
look closely and if it is actually under that pin then, this might sound like a joke, you have to reach execsive speeds to get the needle back to normal position. there are 2 ways to do this, long stretch highway or block up the vechicle and floor it. let me know how it turns out i came across this 5 times in the past year
Apr 28, 2009 | 2001 Chrysler Town & Country
Keypad dosent work on my samsung SGH E315
hi im josh in cebu phils.friend may i help you? Friend the problem when the key pad wont work is the connection your keypad board or dome to the main board.all you have to do are: 1. open your phone with T6 screwdriver for phone and clean the key pad mat or board or dome with a soft pencil eraser and a small brush like tooth brush. 2. check the wire of the key pad connection be sure it has no moist ect. 3. check the keypad IC. if detached re solder it. 4. if you dont have the skills of doing these or if dont want to risk. you let the phone service center do the job.  thats all hope i helped you.good luck
Mar 14, 2009 | Samsung SGH-e315
Everything works in the car but car doesnt start
The security light is staying on because 1 of 2 things, both of which relate to the vehicles VATS (vehicle ani-theft system). You know that little black bump in your key? Well thats part of the VATS system. There is a connection in the ignition that reads the resistance of the pellet. If its not the right one, the security light disables the ignition and starter for 3-5 mins. Now either the wiring is loose on the inside of the ignition switch, or the metal contacts of the key is dirty. Try cleaning the key off with some rubbing alcohol and try again. Or better yet, if you have a spare key that gets used less often, try that one. If that dosent work, its time for a new ignition
Feb 23, 2009 | 1995 Chevrolet Camaro
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Galaxy Radios DX-929 40-Channels Base CB Radio Logo
64 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
