Question about Princeton Digital VL1918 Monitor
Princeton Digital VL1917 Monitor no power no display
  • 11,361 Answers
Very common problem, look for bad caps with leaking/bulging tops as shown in my pictures:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 09, 2010
2 Suggested Answers
tantong
  • 138 Answers
SOURCE: Princeton Monitor VL1917 - No Power
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
The power supply for my Princeton Monitor, Model VL1916, S/N WCCE4307992 has gone bad. How do I get a replacement?
THe AC adapter (power supply) for my Princeton VL173 went bad. I discovered it was the PS and not the display by plugging in an old adapter from an HP printer that I had replaced. The input plugs matched and the power out profiles were nearly identical Only very minor differences). It was just a stab in the dark, but it works! Now my display is 12 years old and still going strong. I hope this helps.
Jun 19, 2011 | Princeton Digital Computers & Internet
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
Monitor does not turn on automatic
change your power cable.
also check your power suply and earthing.
Nov 19, 2008 | Princeton Digital VL2018W Monitor
No volume
Being a person with some experience repairing Princeton Monitors... 776 so far.
If you have not had volume from the monitor right out of the box It would appear the speaker connector was not install or fell off due to poor installation at the factory.
Princeton Monitors have a lot of problems. when they work, they work well.
They are known for their very bad capacitors in the inverterboards.
If the unit runs but you have no green light and no picture Your Caps are toast.
As for your speakers, remove the front bezzel and look for the twisted wires usually black and red with a small white connector. If you find it just danggling, the connector it should go into is on the right lower side of the monitor's screen. It's keyed so installing it only one way will make it work.
Hope this helps.
Sep 10, 2008 | Princeton Digital VL1918 Monitor
Thank you,
Mar 23, 2008 | Princeton Digital VL1918 Monitor
Monitor will not display
Hello, tech support online at Sony was able to help me correct the problems.
Mar 08, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Princeton Digital VL1918 Monitor Logo
126 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
