Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Timer will not tirun on the lights, it stops when it gets to the time to turn on.
Malibu home page
Malibu manuals
Try the manual override >>> un-plug power pack and try loosening manual override with WD-40
It sounds like the clock motor is unable to push the manual override
Don't continue to run power pack or the clock motor will burn up or break a plastic gear
If manual override will not work, or clock will not trip on lights, you need a new power pack
Power pack size chart and wire length
Be sure to buy same wattage power pack as you have
The 300 Watt unit is made for 15 - 20watt bulbs (15 x 20 = 300)
If you buy 600 Watt power pack and hook it up to 10 - 20 watt bulbs, it will burn out the bulbs
Manual also says to replace burned out bulbs ASAP or other bulbs will burn out.
Posted on Oct 09, 2010
Part of a malibu light timer runs but the timer dial does not turn to turn lights on/off
Clock motor has stopped working... there is not replacement module.
Plug power pack into wall timer.
Following link has troubleshoot, warranty, and installation tips to avoid problems:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
Water Heater Timers Save Money
Mar 22, 2015 | Malibu Hardware & Accessories
Timer to start and stop cooking
yes its great go head to walmart get those times for ac power and your good to go with safey cut off they all have
Jan 27, 2008 | Crock Pots & Slow Cookers
Timer light stays flashing all the time how do i get it to go out?
You need to go in the on screen menu and set your clock. This will stop the flashing.
Aug 30, 2014 | Quasar VHQ400 VHS VCR
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
How do we set the time to stop on a UPM ETW350? I know how to set the time to start but i do not know how to set the time to stop. Thank you
In wall timers and manuals are shown on following link.
http://waterheatertimer.org/Programmable.html#ETW
ETW350 manual:
http://waterheatertimer.org/UPM-etw350.pdf
Select from 3 different functions:
1) 24-hour Programmable
2) Countdown timer function so lights turn off after period of time
3) Random function so lights turn on randomly and house looks lived-in
I am not going to write out the steps because they show in the manual.
But a specific part of the manual might be confusing.
So add a comment and I will help until we will get the timer working.
Nov 20, 2010 | UPM Programmable Wall Switch Timer
Timer runs correctly until it hits the tripper, then it stops and wont turn the lights on. I can push through manually, but is the timer defective?
Sounds like the motor is getting tired. Before investing in a new timer , use a little light oil (NOT WD40 because it will deteriorate the electrical components in time) to lubricate the mechanism.
Jun 07, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Timer stops at on postion? transfomer works, have to do it by hand
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
May 04, 2010 | Intermatic Malibu 300W Power Pack...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Jul 05, 2009 | Hardware & Accessories
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
159 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
