Question about Microwave Ovens
I just bought a kenmore fridge with a bottom freezer mod# 596.66039603 ser# k03274819 and I cant get the fridge or freezer settings to change , The #'s stay at 0 for both going up or down
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Maytag Bottom Freezer Fridge only a few years old was replaced to sell the house. We just bought our house, moved in and the dishwasher wasn't working so we got a new one. Now our fridge is humming and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Microwave Ovens
Ice and frost on coils inside freezer
Possible that the auto defrost timer is faulty and is not working to the scheduled timing causing the frost to build up and block the coils in the freezer.
You will need to check this timer at the rear bottom of the fridge , check if thee timer clicks on or else replace,
Make sure that the thermostat is also working and shut the compressor when the thermostat is set low.
Sep 27, 2010 | Microwave Ovens
My freezer is working fine but the fridge is not cooling. It is a kenmore side by side 26 inch and is 9 years old.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 24, 2010 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
We have a Hotpoint refrigerator/frezzer. It intermittently makes fan noises and stops making ice. Where do we find someone who can service the unit?
I hope your microwave doesn't make ice !!!
Are you in the GTA (Greater Toronto Area). If not I can tell you what is happening.
All fridges have a timer so that the freezer goes thru a defrosting mode for about 3hrs
In that 3hrs there are hearter in the walls of the freezer to melt the ice.
As the ice melts , there is a drain from the back of your freezer down to the bottom of the fridge is a vaporator tray. The hose could be blocked and the water can't drain and after the defrost mode all that water changes to ice and it stops the fan
Take the time to make sure that hose is fre from abstruction
Jul 14, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
