Question about Diamond Multimedia ( VC500) Video Capture
Ok, so I bought the Diamond VC500 multimedia recorder, and what I want to do with it is to record videos off of my playstation. I have all the right hardware i think; three 1 male 2 female y splitters, 3 female to 3 female extender, the actual Diamond VC500 hardware, and the playstation and all of its cables that all corrispond to the same cables (i.e. white to white, red to red, yellow to yellow) and I have hooked up the USB port to my computer and have downloaded all of the softwares that go along with the hardware. But the problem is, that everytime I go on my playstation to try to record something, the video and the sound show up on the TV screen, but not the computer software device that came with the Diamond. What I think the problem might be one of two things; that I have an HD TV screen and the computer i bought about 6 years ago might not be able to process as many pixels as the software needs to function, or the other problem might be that i have not configured the software settings right. If you are familiar to the software then the settings are as follows: Video format: NTSC_M Import Source: Composite Record: (Format) DVD Capture Button: Capture Video. If anyone has any idea what I'm doing wrong, please email me a.s.a.p. Thanks, and if it means anything, the computer I'm using dosn't have an internet connection.
Can record video and sound but on screen only has horizontal lines
Send it back. Mine did the same and they replaced it no questions asked.
Dec 17, 2013 | Diamond Multimedia ( VC500) Video Capture
Help Me remove lag please
Maybe you need to switch to another video recording software instead. Smartpixel might be a good choice for you, it is compatible with all the PC games, and it has a PIC in PIC mode which allows you comment on the webcam while game capturing, it is simple and easy.
May 03, 2013 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
When I connect the VC500 to the computer and the vcr, most times, the video plays fine. When I try to record, the video skips - it records - but skips and the recording skips as well. It's almost as if...
Hello mabusse
The sofware is too heavy for your computer . You can improve it's function buy setting the quality to a lower level , it will record smootherly but of course the image will be less sharp .
I experienced my self that the best way to succeed in recordong video tapes or tv programs is to use a stand alone recorder .
Best regards ,
fanaudi .
Mar 03, 2011 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
83 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
A Vlad Fuica
Level 1 Expert
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
