Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Cant do anything
It says "Not enough space for Music DB, please free 4 MB" when I turn it on, and then it shuts itself off. When i plug it in to the computer the same message pops up but it doesn't shut off and the only way to shut it off is to remove the battery.
  • 8,596 Answers
Database is corrupt - reformat the player.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 30, 2008
drez
  • 30 Answers
SOURCE: Error message at startup says..."Not enough space for music DB...must free up 6 MB of space.
your going to have to format your mp3 player.
Posted on Sep 11, 2007
  • 10 Answers
SOURCE: Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Posted on Dec 01, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: displays msg. to free up 30 mb -- but can't free up space
Reformat the player is all you can do - you will not be able to download an upgrade that will prevent this from happening in future, b/c the upgrade is not Mac compatible
Posted on May 28, 2008
SOURCE: Not enough space for Music DB, please free 8 MB
just backup your Sandisk, format the Sandisk, then copy all back, it works for me this way
Posted on Jun 15, 2008
SOURCE: not working
Hey guys the best way to do it is by puttin da player in the "Hold" mode and while connecting it to the PC keep the middle button (the round one) pressed.....this shall give access to ur player.....take a back up of da songs and then format the player as suggested by "Computerep".....tht shall fix da problem....Adios
Posted on Oct 26, 2008
It keeps saying not enough space for music DB please free 90 MB when i turn it on
Remove the microSD card, then connect the Sansa to your computer. Delete one or more files (music, photos, videos) until you free up the required amount of memory.
Feb 10, 2010 | SanDisk Sansa Clip MP3 Player
Cant remove 30 mb
try looking on a differnt site!
Jan 14, 2010 | SanDisk Sansa Clip MP3 Player
NOT ENOUGH SPACE FOR MUSIC DB
if it detects in your computer then you can try formatting it....if not,try sliding the hold key to off position then connecting to PC...it must get detected as a removable disk...format the disk...
Sep 11, 2009 | SanDisk Sansa c240 MP3 Player
"Not enough space for music DB. Please free up 30 MB"
The mp3 manufacturers are often being disingenuous - they plug an mp3 player into a Macintosh, and it shows up, so they say, "Hey! It's Mac-compatilbe!" But, the software is certainly not Mac-compatible, so if you ever experience a problem, there is no way to fix it. Also, the Sansa e200 series does not recognize iTunes format.
In general, I would agree that you need to reformat your player, but I have no idea how to do that on a Mac (I'm good at a lot of things, but I'm Mac-illiterate).
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
