Salut quant je branche mon copieur RICOH AFICIO 1224C, sa affiche erreur fonctionnel avec le code d'erreur:sc672 svp aidé moi à resoudre ce problème
Elbastardo
  • 21 Answers
SOURCE: Bonjour mes chers. Mon copieur
Verifie pour ton unite de fixation pour ta temperature ou tes thermistances si elles sont bien en contact avec le rouleau de fusion
Posted on Sep 14, 2010
jqsababa967
  • 145 Answers
SOURCE: probl?me H 4
KEY IN THE FOLOWING KEYS
PROGRAM.ENTERPT,CLEAR. INERPT...this will give you access to the service mode
than ENTER #14 THAT PRESS THE START KEY
GOOD LUCCK
Posted on Dec 15, 2008
  • 990 Answers
SOURCE: error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
SOURCE: jai un probleme avec un copieur Gesttner 3220 . A
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Posted on Apr 16, 2010
  • 22 Answers
SOURCE: MON PHOTOCOPIEUR AFFICHE LE CODE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Posted on Feb 10, 2011
Bonjour moi j'ai un pc alienware avec windowa 7 je veux instaler mon jeux cardoza entertainment avery cardoza's casino comment je fais merci
Allo!
J'ai trouve ce link pour toi!
J'espere que va t'aider assez pour rouler ton Cardoza's Casino sur Windows 7.
Donc, voila le link!
(si ma solution t'as aide donne-moi un RATING, S.V.P.! MERCI!)
Mar 07, 2011 | Computers & Internet
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Probleme wifi avec htc touch diamond
Salut,
Avec mon HTC Touch Cruise j'ai dû mettre la puissance du signal au maximum sur le HTC pour pouvoir naviguer, si je le mets sur moyen ou faible il se connecte mais pas possible de naviguer.
J'ai trouvé cette solution sur un forum italien et pour moi ca a marché.
Sep 23, 2008 | Zyxel P660HW-D1 Router
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
La batterie faible
le problem est avec la battery, tu dois la changer.
Mar 06, 2008 | RCA Lyra RD2762 MP3 Player
Mon recepteur fta viewsat ultra est bloque
As-tu le cable db9? Et qu'est ce qui apparait sur la fenetre de ton ultra quand tu l'allumes?
Feb 06, 2008 | Audio Players & Recorders
Install Image Mixer3 for Panasonic SDR-H250EB
salut tout le monde je veut installer le cd de mon camera "panasonic SDR-H250" pour la fonctionner sur mon ordi mé le probleme ke jé perdu le cd é je doit l'installer depuit le net svp aidez moi koi faire é merci d'avance
Dec 29, 2007 | Video Cameras
74 people viewed this question
jasbo
jasbo
