Question about Health & Beauty
I have a B P monitor # BP3AD1-1-LF the C D that came with the B P monitor will not run in my computer as the compartment that runs C D 's is vertical. can you send a a web suite where I can download? thank you C.C.Patrick> ccpat41@yahoo.com
  • 55 Answers
Place the CD in CD Drive of your computer. Hold CD slightly with one finger and press the close button to close CD drive. Move gently finger with tray and leave it while it closing at end, you will be done. INSHALLAH.
Posted on Oct 09, 2010
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
Mar 03, 2017 | 1998 Lincoln Navigator
MR5 Mk1 studio monitor. The HF driver works; the LF driver does not. What's wrong?
An internal connection could be broken. You will have to open up your monitor to find out.
Aug 15, 2015 | Mackie Music
MY WHIRLPOOL CABRIO WORKS FINE ON EVERY SETTING EXCEPT THE SHEETS/TOWELS SETTING. MACHINES RUNS FOR A FEW MINUTES, THEN CODES LF. I HAVE UNPLUGGED, CHECKED ALL PIPES, SREENS, DRAIN PIPES.
LF is a long fill code,taking too long for water to enter.
Is the cold water valve filter screen clean?
Is both Hot and Cold water turned on?
The LF can also be related to the pressure switches.
Jul 25, 2011 | Washing Machines
I discovered that the material which came with the product allowed me to download the software using only Windows Vista or Windows XP. My system is Windows 7. Is there anything I can do about this or...
Hello
You just try it with any other computer running on Vista or XP. Connect your device through that system and download the software. Some electronic devices like blue ray player, have internal LAN card fitted with it. If your device is such a type, you can download the software directly connecting it to an external broadband modem. We have got the software like that for a sony Blue Ray dvd. But yours have no video output device fitted inside to monitor the function. So you must connect it to an other computer itself to get the software downloaded. If it can't possible contact the manufacturer for support. Sometimes they may have the software on CD format. If so you can do thing very easy.
Oct 15, 2010 | Life Fitness Ultra Blood Pressure Monitor...
I have a 3MQ1-LF bp monitor. I am trying to
To erase the monitor's memory, press and hold the "M" button until the letters "CL" appear on the screen. Release and press the "M" button again. The monitor will beep twice, indicating that the memory is now empty.
Mar 15, 2010 | Life Fitness Health & Beauty
Where is the battery located?
The battery is located under the cover immediately behind the Head lamp assembly <DRIVER side> remove the three screws that secure the cover and push the 4 tabs on the heat sink looking with the cords running from it. (I have no idea what this is does)you can now remove this larger cover to reveal the battery the tighest space I have ever seen in a GM.
Feb 28, 2010 | 2005 Chevrolet Equinox
I have a front load kenmore washer, the problem I have is that I have to take out th soap dispencer and dump the water out of it.
Remove the drain hose and then run water though it to check whether the hose is blocked. ... Do not overfill the soap dispenser compartment. ... Bleach doesn't dispense during a delicate cycle
Rinse the machine with no load and no detergent. Run a regular wash cycle.
Nov 16, 2009 | Computers & Internet
Lf-x1
ok now i see, the way i see it is that you can put an IP address on the lf-X1 and by then configure it wirelessly on your mac? right, id there a utility by any chance that you can install on your mac so that it will see the sony base station? they should have the same segment for them to communicate still. actually you should create one by using a utility that came with sony, or you can check the IP adrdress of your mac so that you can assign one to sony station.
but here's what, check this link. this will help you set it up: click HERE
pls rate solution, thanks!
Jun 26, 2008 | Sony LF-X1 12.1 in. LCD Television
Lf-x1
are you saying that you want to set both computers in one network? here's the thing if i got you correctly, you said that one monitor is not functioning or something right? but anyways if you want to get both computer towers IP is for you to click on start then hit on RUN then type in CMD then enter to enter the command prompt then on the command prompt type-in ipconfig for you to know if you have the same IP address, default gateway, and subnet mask, IP address should have the same first three segment i.e is 192.168.192.XX and will differ on last segment to separate or assign it to a device.
Bi amp
Hi there, I am assuming that you wish to BiWire the speakers. This involves removing the link on the back of the speaker box and running additional speaker leads for the HF drivers, as well as cable for the LF drivers. BiWiring allows you to use different cable that has been designed with high frequency signal path in mind. It may feature things like silver plating, low capacitance, or as many other "features" as can be tagged to the cable to sell it as a specialist HF conductor. The benefits may be subtle, and not be that noticeable. It does isolate the potential voltage drop along the length of the cable associated with LF energy away from the HF side of the speaker system, and take advantage of Skin Effect, where HF energy tends to travel on the surface of the conductor.
Using a single cable for each channel and leaving the links fitted is perfectly fine and will operate no worries. You could go and spend the extra cash and upgrade your cables to HF and LF BiWire.... the sky is the limit on cost here for what may not be a noticeable difference:)
BiAmping in a different story where much more performance increase is achieved by using a separate channel to amplify HF and LF signals. But you need an amp that has a built HF and LF outputs for each channel to do this. They exists but I have not seen any surround amps that have it.
Go with decent quality realistically priced speaker cable first, then add your HF BiWire to the rig if you are looking for that little bit extra from it:) Good luck, and happy listening.
regards
Graeme
Feb 28, 2008 | Monitor Audio Bronze B4 Speaker
Health & Beauty Logo
281 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
