Question about Sony KDF-50E2000 50" HDTV
Lamp door is securely shut on KDF50E2000 50 inch DLP Sony Wega. Unit turns on for several minutes and then shuts off and blinks 3 red lights
    New Friend:
NEED LAMP DOOR KDF50E2000
Posted on Jul 27, 2013
  • 81 Answers
SOURCE: Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Posted on Apr 22, 2010
  • 135 Answers
SOURCE: i just installed a projection lamp in my sony wega
Check the lamp door. It may also have a bad thermal fuse.
Posted on Feb 23, 2010
SD Tech
  • 14553 Answers
SOURCE: 3 red blinks after power on
3 BLINKS SHOULD mean lamp door not properly closed.
If you look carefully at the lamp door --is it warped? Look at it edgewise--if it is bowed at all it is the problem.
Heat gets it from the lamp.
Here is a way to prove this for yourself--the door has a plastic peg on the back--when it is in place the peg engages a small lever--usually blue in color and you can see it with the door removed.
It is there to prevent the set from being operated with the door removed.
What I suggest you do is with the door removed engage the lever with something NOT METAL a plastic piece or even a match stick--with the lever pushed forward (which is what the peg should do) turn the set on.
If it comes on and works you just need to replace the door--very common on this set.
Let me know if the set works this way--DO NOT LOOK AT THE LAMP WITH THE DOOR REMOVED AS IT CAN DAMAGE YOUR EYES.
IF the set works this way confirm the model number to me--Usually there are at least 3 sellers on EBAY selling OEM doors for this set at about 20 including shipping--Sony will have them for less but often are out of stock because this is a common problem.
If this helped you, rate this solution as I do this here for free.
SD TECH
Posted on Dec 28, 2009
SOURCE: KF-42E200A
my sony shut off all the time what can i do could it be the lamp or reset
Posted on Mar 18, 2010
  • 1039 Answers
SOURCE: Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Posted on Apr 01, 2010
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Oct 19, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Apr 24, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDF-50E2000 50" HDTV Logo
341 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
