Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The picture is "zoomed" cutting off heads, etc. at the top of the screen. Can't seem to find a solution on the remote or t.v. setting, but the "info" bar at the top of the screen shows zoom ratio of 16:9. How do I get it back to normal?
  • RCA Master
  • 5,807 Answers
The picture is
You may have to check these out
Posted on Oct 09, 2010
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
Picture cut off for my flat screen pansonic tv, zoom adjustment grayed out and i cannot adjust?
Without that model number (should be on receipt or owner manual for set) do not expect anything here other than a general answer.
If the zoom is grayed out it may be normal depending on what is connected and how. If you are using a box of some kind hooked via rear inputs the box may be the reason---it may control or cause this to be grayed out---a simple answer to a question: Do you have the same problem with a DVD etc hooked up to a rear input?
Apr 18, 2012 | Panasonic Televison & Video
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My kids were playing with the buttons on the tv, and itseems like the picture is now "stretched" vertically - the tops of heads are cut off, and it seems like some of the picture is missing from the sides....
there should be a zoom, or strech, or even the letterbox option somewhere. What your describing is a enlarged picture that doesn't fir the screen, like if I select zoom on my remote.
Dec 10, 2009 | JVC AV-36D302 36" TV
The top of people's ehads on the screen are cut
Is your zoom function on, making the picture too close? Check the zoom function on the TV AND the cable remote.
Sep 27, 2009 | Sony Televison & Video
RCA D52W17 Picture is cut off at the top of screen
is it a black area on the screen? or just cant see the heads anymore? either way its proabaly a setting on the remote such as zoom or ratio
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
