My Toshiba 2830c color copier is showing error code C390. Can't get a service tech over the weekend. Wondering if this is something I can readily fix myself?
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
  • 653 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 2187 Answers
SOURCE: Sony PFM 500A2WE 12 22 error code
The error indicates issue with the power supply and the deflection stage, Check first the cable. If you plan on troubleshooting this yourself check first the warranty. Inspect the power supply circuit if there are leaking capacitors. As for the deflection stage I would recommend a technician to have this checked.
Posted on Aug 04, 2009
FixinFax
  • 3085 Answers
SOURCE: Toshiba copier service mode.
Only a technician can decipher the Call for Service error.
Posted on Jun 19, 2010
john224
  • 1378 Answers
SOURCE: heater displays error code E06
Thank you for posting your question here on Fixya.com.
Page 43 of your manual, found here suggests both E05 and E06 errors mean the issue is related to "...(the) fuel supply, thermal regulator, check for correct orifices, etc...". It also touches on the possibility that if the unit was converted from NG to PP or vice-versa that the orifices are not correct.
Start with these two areas...if you need additional assistance please comment to this answer with details from what you find while checking these areas and I'll try and help you from there.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Apr 23, 2011
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
How do I repair a ca00 error
CA00 is a image problem.
It can be caused by insufficient of developer materials or main charger problem.
Mar 04, 2015 | Toshiba E-Studio 2830c Color Copier...
Toshiba 2330c error cd71
Waste toner transport motor drive locking error.
Jun 10, 2014 | Toshiba E-studio 2330c 2830c Color...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
C390
[C390] Auto-toner sensor-C abnormality (Cyan)
<Color toner low density>
When you check the printing status to find out that the color printing ratio isless than 5%, color toner low density might be the cause.
Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged number of sheets setting".
If the color printing ratio is 5% or more, check the following.
(1) Is the developer unit installed properly?
(2) Check if the connector CN340 on the LGC board isdisconnected from the auto toner sensor or the harnesses are open circuited. Correct if necessary.
(3) Check if there is any foreign matter such as toner in the drawer connector of the equipment and fuser unit or the connector of the auto toner sensor. Remove if there is and reconnect it.
(4) Service or replace the auto-toner sensor.
Apr 04, 2014 | Toshiba E Studio 2330C
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
Estudio 2830c
Double check your printer driver.
Oct 15, 2013 | Toshiba E-studio 2330c 2830c Color...
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Mar 19, 2012 | Office Equipment & Supplies
Hi, I have a Toshiba e-studio 2500c Color Copier. All of the sudden I've got a few errors. First a C390 then a CA00, but I was still able to make B&W copies, now I've got another error C970 and...
you seem to be having some issues ... ... ... the codes you are getting are related to the color calibration. possibly with the cyan developer unit or the high voltage board. to properly diagnose and fix the problem you will need a technican to fix the problem
Jun 22, 2011 | Toshiba e-Studio 350 Copier
251 people viewed this question
k24674
jasbo
jasbo
