Question about Hitachi 43UWX10B 43" Rear Projection Television
The sceen shows a arch on the bottom and a bow at the top in the middle of the screen? And the blue and green are not aligned how do I fix . Thanyou
  • Hitachi Master
  • 5,138 Answers
Replace the Convergence ICs ,they will have PN# on them STK392-110s use 120s Mats has them 1-800-628-1118
Posted on Oct 09, 2010
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Jul 13, 2009 | Samsung PCL5415R TV
Pt5598 rplaced convergence board no luck.
If the picture is still bowed, the power supply fuses are open.
Check the power supply on the red connector for + and - 20 volts.
The fuses are on the main board,are on the deflection module in the middle, tward the front of the TV. They should look like green (or brown) resistors. An ohmmeter check will show which ones are bad.
They should be 3.5 amps. Replace with 4 ohm GMA fuses with pigtails if you can't find picofuses. I also had a set that would fry the 1 ohm resistor on the 20 v supply. This was near the fuses.
I replaced the whole module to fix that.
I hope this helps. Lee, www.crazycomputers.com
May 31, 2008 | Akai PT5598HD 55" Rear Projection...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Another Convergence Problem?
dont move the pic tubes that will be a costly mistake the problem is still your ics replace them all you should have two check for bad solder connections
Nov 12, 2006 | Toshiba 50HX70 50" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
