James Albert Posted on May 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Teac cassette deck records at very low volume
I have a Teac V-350C cassette deck that records at a very low volume level. The volume level indicator shows a normal volume level during record, the sound level also seems to be normal when monitoring the sound through the deck's headphone jack. There is no distortion in the sound, it just records at a very low volume level. Cassettes recorded on other decks play at a good, normal level on the Teac. So, the problem seems to be record only, not playback.
Sam Palermo
Level 3:
  • Audio Player... Master 1,267 Answers
  • Posted on May 03, 2013
Sam Palermo
Level 3:
Answers
1267
Questions
Helped
255725
Points
1842
As I remember this deck is may not warrant the cost of a repair but in case you are attempting the repair yourself, the first thing to do is clean the heads real well. After that get a schematic off Hi Fi Engine if they have one and you will have to trace where the signal is missing. If both channel are the same it is possible a electrolytic capacitor has shorted in the Bias section of the record circuit. Levels do not shift downward all at once two channels at a time unless there is a common problem. I have know capacitors of the 10 V type to short and take the entire function of a deck out. Change that one 10 V cap and the deck works again. Of course this assumes you have the ability to change a electronic component. If not off to a technician it goes.
Grubhead
Level 3:
  • Audio Player... Master 5,755 Answers
  • Posted on Jan 25, 2009
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1660169
Points
11417
Tape decks have a record amp, depending on the age of the machine it will probably be an IC. Yours might have failed. See if you can identify it or try and get a C diagram. To locate it follow the leads from the head. If your lucky it might have 'Rec Amp' on the board. Their maybe a preset marked 'rec level' for each channel. The (IC) box with legs - near them will most likely be it. Don't adjust the presets unless somebody has tampered with them before. (they will look to be sitting around the middle if they are OK).
2answers
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
I want my teac w600ro pla y deck a then deck b then stopyt
The unit needs work but it might not be worth repairing- that is up to you but most dual cassette decks were very poorly made units. That is why I always steer people away from them. I worked at Teac in Chicago and in fact still work on decks now under the skywave tape deck repair if you were to look me up.
Record button wont press down
Record button can be pressed down only if you placed a cassette into the deck and if this cassette was not protected against recording. This protection is mechanical, and can be found at the top of the cassette. One for the A-side and another one for B-side.
Thanks,
gylacz
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
2helpful
How do you raise the recording level on a teac rw d200? Im recording into the recorder from another deck and when i playback its so low you can barely hear it
I have the same problem. Are you copying an analog source? (tape?) Even though the "0 db" level is activated, (button on upper right on front panel) the level rises to -12...max. I suspect the auto-level is preset at the factory? Even with an EQ boost there is no level increase. Drives me nuts! Must have to recalibrate it; but I've no idea how...
Teac Cassette Deck V-518X. No Record Audio.
Found a pinched wire under the cassette deck from the record head. Move the wire out from under the cassette deck. Works fine!
Thanks!
JOHN
3helpful
My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
[email protected] Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
 Grubhead
Grubhead
SmartAviator
SmartAviator
