PCPrivacy Cleaner - Computers & Internet
  • 981 Answers
Privacy way too clean already. Go to a truckstop and get some test grit on your privacy first.
Posted on May 30, 2008
How do i clean the mass air flow sensor on a 1988 3.0 v-6 4x4
These are best cleaned with spray brake cleaner.
Oct 14, 2015 | Cars & Trucks
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Replace air filter
Air Cleaner Element -- Explorer 4.0L and 5.0L
Removal
1. Release the air cleaner clamp and position the LH side of the engine air cleaner (ACL) (9600) and air cleaner outlet tube (9B659) out of the way.
2. CAUTION: Do not tamper with the sensing elements located in the mass air bypass of the mass airflow sensor.
Remove the air cleaner element from the RH side of the engine air cleaner.
Installation
1. Clean all inside surfaces ofengine air cleaner. Refer to «Cleaning and Inspection» in this section.
2. Install air cleaner element.
3. Position engine air cleaner halves together and close the air cleaner clamp.
Mar 07, 2011 | 1998 Ford Explorer
How to removing engine aif filter on 06 honda element ?
FOR A 2.4 LITER ENGINE
Air Cleaner Element Inspection/Replacement
  1. Remove the air cleaner bolts (A) and the Air cleaner Housing cover (B).
  2. Remove the air cleaner element (C) from the Air cleaner Housing (D).
  3. Check the air cleaner element for damage or clogging. If there is damage or clogging, replace the air cleaner element. Do not use compressed air to clean the air cleaner element.
  4. Clean and remove any debris from inside the Air Cleaner housing.
  5. Install the parts in the reverse order of removal.
  6. Good luck
Oct 20, 2010 | 2006 Honda Element
Panasonic copier DP-6010 showing Error E03-51
Description
Corona Wire cleaning
Causes
1. Cleaner Home Position Sensor 1 connector is disconnected. 2. Cleaner Home Position Sensor 1 is defective. 3. Cleaner Home Position Sensor 2 connector is disconnected. 4. Cleaner Home Position Sensor 2 is defective. 5. Cleaner Motor Drive Mechanism is defective. 6. Corona Mechanism is defective. 7. Cleaner Motor connector is disconnected. 8. Cleaner Motor is defective. 9. DRV PCB connector is disconnected. 10. DRV PCB is defective. 11. SPC PCB connector is disconnected. 12. SPC PCB is defective. 13. LVPS is defective.
Jul 21, 2010 | Panasonic WORKiO DP-6030 All-In-One Laser...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Where is the air filter and how to replace it?
Six cylinder:
The air cleaner element is inside the air cleaner housing on the left side of the engine compartment. (It has a large hose connected to it).
To replace it: Disconnect the hose from the air cleaner housing cover with flat-tipped screwdriver.
Loosen the four bolts, and remove the air cleaner housing cover.
Remove the old air cleaner element.
Carefully clean the inside of the air cleaner housing with a damp rag.
Place the new air cleaner element in the air cleaner housing.
Reinstall the air cleaner housing cover, and tighten the four bolts.
Connect the hose to the air cleaner housing cover with a flat-tipped screwdriver.
Hope this helps you.
Jan 08, 2010 | 2004 Honda Accord
How to replace engine air filter in 2001 honda odyssey
The air cleaner element is inside the air cleaner housing on the driver's side of the engine compartment.
To replace it:
1. Remove the two pins holding the air intake cover by pulling the head on each pin. Remove the air intake cover.
2. Loosen the four bolts by using a Phillips-head screwdriver.
3. Disconnect the clip from the bolt on the air cleaner housing, then remove the air cleaner housing cover.
4. Remove the old air cleaner element.
5. Carefully clean the inside of the air cleaner housing with a damp rag
(The coolant lines inside the air cleaner housing may be warm. Do not open the hot air valve when cleaning the inside of the air cleaner housing)
6. Place the new air cleaner element in the air cleaner housing.
7. Reinstall the air cleaner housing cover. Reinstall the clip on the bolt; make sure the clip is under the washer. Tighten the four bolts.
8. Reinstall the air intake cover. Reinstall the two pins and secure them by pushing on the heads until they lock.
Hope this helps you through the process.
Nov 23, 2009 | 2001 Honda Odyssey
A message on my screen (which will not go away) advises me that my computer is in danger of a virus and that privacy information is in danger. This message is from PCPrivacy. They want to charge $39.99...
Do not panic, this could be an infection... Turn off your Comp.
Boot up to the safemode with Networking, Try if you could Run Updates to the Maccafee..
then scan your Computer From Normal mode...
Remove all the infections.
Your computer should do just fine.
Jul 17, 2008 | Computers & Internet
Compaq presario A75206OM
hi friend u need to contact 24 hour hp chat technision support
Jul 10, 2008 | Compaq Presario Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
