Question about Lexmark Office Equipment & Supplies
Lexmark X7530 fails to connect cannot receive faxes
  • Anonymous Jul 30, 2008
    Although during the day the fax shows connecting for a long time, then 'failed to connect' when at night the attached computer is turned off it receives OK
  • krda Nov 24, 2008
    Some faxes connect and some don't. Ther printer shows "connecting" for some time and then fails. I do receive some faxes but not all and 2 or 3 senders that I know of consistently fail.
I dont have cable and drivers. can you tell me plese what kind of cable model must be used if the battery misseng?
Posted on Nov 23, 2008
  • mariuspandia Nov 23, 2008
    connect the printer without battery
We can't receive a fax!!! how are we supose to connect with a phne line and the computer???
You don't need to have a computer plugged in to the Lexmark printer to receive faxes. Here's an article on How to Configure the Lexmark X7170 to Receive Faxes. Just click on this link: http://bit.ly/d643uT. If you are sharing your home phone line with the fax and you have an answering machine on the same line, make sure to configure the answering machine to pick up first then the fax machine. Voicemail feature can also block incoming faxes. Once voicemail picks up the fax, signal won't be passed on to the printer. But if you want, you can also contact Lexmark technical support to further investigate the problem.
Aug 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
My lexmark x4270 can't receive or send faxes. keep saying fail to connect, try again. please help.
Hi have you tried installing the most up to date drivers recently because they do change and if so sometimes there are seperate drivers for a lexmark. Also due to it being faxes make sure your firewall or anti virus aint getting in the way of it try disconnecting it for a brief moment then try sending if it works then go through your protection settings and so on
Hope this helps
Carl Redding
Jul 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
I cannot receive faxes on my Lexmark 7350 All-in-One. I can send them Fine
hello there, Try Connecting the Lexmark All-in-One directly to the phone port...but make sure that Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
If this does not work then do get back for any further help.
Thanks
Mar 05, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
LEXMARK PRINTER
change the dialing mode from tone to pulse
Jul 24, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can send but not receive faxes
Is that a USB connected Lexmark unit?
Apr 24, 2017 | Lexmark X6570 InkJet Printer
Can not fax the paper say connection failed lexmarkx4270
Here's a link to the user guide, navigate to the "Fax Troubleshooting" section.
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
If you are still having problems please let me know and also provide information about how the fax is setup.
Jun 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
We cannot receive faxes. The machines tries to connect but fails due to a transmission problem
you should disconnect the phone line and the power to the fax , they will lock up sometimes and need what is called a cold reset , otherwise there may be a problem with the filter or the fax itself
Oct 16, 2008 | Lexmark Office Equipment & Supplies
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
300 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
