Question about Panasonic KX T7220 Corded Phone
The snowboard shop I work in has a Panasonic XDP Model KX-T7220 corded phone, how do I program the phone so the 24th line is our intercom?
  • Panasonic Master
  • 2,460 Answers
I see what you're asking, but I'm not exactly sure what you mean. The INTERCOM of all Panasonic systems is a feature where you get internal dial tone. That button cannot be reassigned. However, in some installations, we will tie an outside line to paging equipment which when you press the button you go to an external amplifier, or you use the button to dial the EPG code (321 or 322) or 32* or 33* for all zones/page.
If you're talking the latter, you can press PROGRAM 99 the 24th button, and dial 0+01-xx STORE to put a specific line (trunk) under the button, or 2+3xx STORE to put a paging access code under the button.
In all cases, you exit programming with PROGRAM 99 or just pick the handset up and drop it back down in the cradle.
I'm guessing (the Pana gotcha!) that you forgot the "2" in the "convert a CO/DSS button to one-touch" command.
Carl
Posted on Oct 09, 2010
We have a business panasonic xdp system and are unable to change the greeting message. How do we access this initial contact message. We are able to change individual mail boxes on the system.
Assuming you dial 165 to get to the voice mail system (a TVS type box) you press #6 * 998. You better know the password if it asks and you need to know where the greeting was recorded. It sits either in a Custom Service box (1-100) or a Company Greeting (1-32).
I'd be hoping that someone left a TVS Installation and Programming manual with cheat notes lying around. If not, there's a way into the TVS via a terminal program and the DB-9 serial connector on the box. That will let you read the database.
Your Panasonic installer/dealer might have the passwords and setup in their records.
Carl
Jun 28, 2011 | Panasonic KX T7220 Corded Phone
I bought five Panasonic KX-T7730X phones. The business i work for has a Panasonic KX-TD1232 system. I unpack all phones and tried it on different extensions and won't work. there isn't ant pulse....
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
Jun 23, 2011 | Panasonic KX-T7730 Corded Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
Panasonic KXT7220 Corded Phone - the "message"
Well, if you could look at the display, it would tell you who left the message :-)
Since you can't, on the intercom 700 plus your own extension clears ALL messages to that phone.
Carl
Dec 27, 2010 | Panasonic KX T7220 Corded Phone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
D816 phone system with new KX-td7895 cordless phone that we cannot get the phone system to recognize. I have been reading posts that say to disable the XDP feature (program 600) but I cannot find a menu or...
That model is either a system phone or a single line set. If you're going to use it as an SLT, then you can plug it into the XDP and enable the port in 600. 600 is a SYSTEM program accessed from the main phone and enabled per port.
If you operate in the multi-line mode, you need to wire this phone to its own port on your 816 system.
Carl
Oct 15, 2010 | Panasonic KX T7220 Corded Phone
How do I get the "Tel to" ( the line hookup out the back of phone for a cordless) line to work on a KX-T7433
You need 3 things, wiring, programming, and a cordless phone.
There needs to be a 4-wire connection from the TD system, you need to turn on the XDP port in programming, and you need to have a single line device. You can test the first thing by unplugging the digital phone and plugging the cordless phone directly into the socket. If it works, then you have the proper wiring. Now, in programming you need to enable the Jack in 600 and make sure the 39x code on the intercom says unmerged. I don't remember which is which, but I'm guessing (50-50 chance) that 390 makes the XDP stand alone.
Carl
Sep 30, 2010 | Panasonic Lands Phones
Have a kxt-7453 and need to attach a heart monitor which needs an analog phone line. On the back of the kx-t7453 is an XDP jack to attach a fax machine. This would be the analog port; however, there is...
It depends on the system the phone is wired to. A TD-816 has modular plugs on the base cabinet, but uses an Amphenol cable for the expansion units, and a 1232 is all Amp. You need 4 wires to make it work. The quickest way to test is is to unplug the digital phone and plug a single line set into the same jack. If it works, then you need to do some system programming. If it doesn't some wiring.
The digital phone uses the outer paris of a 4-conductor jack, and the analog/XDP is on the inner pairs. We always use 2-pair jumper wire on TD systems, but some installers cheat and don't wire both pairs. You'll know if it works because the single line phone you plug into the jack alone will have the same extension number as the digital set.
If you have dial tone there, by default, when you plug in the digital set, the XDP has to be turned on in program 600 and there's a merge/unmerge comand. The XDP port is 100 more than the station (ie 103/203) and the code to merge/unmerge is 390 and 391 (I can't remember which, so look at the display as one merges (probably 1 and one doesn't 0)
You'll have to teach the device to dial "9" or an access code 81-88 to get a specific line or group.
Outside of that, it's not that bad to program.
Carl
Sep 18, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
Panasonic KX T7220 Corded Phone Logo
241 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
