Question about Sharp Televison & Video
Part of my lcd tv screen is "blacked out" and another part has a plaid pattern. About 3/4 of the screen is visible for watching tv.
    Genius:
  • 2,035 Answers
This is the problem with the onboard capacitor get it replaced it resolve the issue...............
Posted on May 30, 2008
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I have a un75es9000f and the picture looks plaid I had some movers move it and after we hung it and turned it on it looks plaid and has a bubble on the bottom of screen any ideas of the problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Televison & Video
Dynex 37 hiss and plaid screen
There are some components that have gone bad in the board. It could also be due to moisture inside. Please do not continue to use it and refer it to a qualified service technician.
Jul 19, 2012 | Dynex "- 37"" Class - LCD - 720p - 60Hz -...
Green Plaid lines on Samsung HLR5067wax/xaa-
These are the Tests that should be run to determine which board is bad.You should call a good TV Tech if you are not familiar with this TV.
- The DDP1011 on the DMD board has a feature to display internal test patterns.
- DNle, which is an end port in the digital board, has a feature to display internal test patterns.
- The analog board sends signals to ADV7402 on the digital board.
- The analog board is the first output and the digital board is the second one, followed by DMD, which is the final one.
■ Diagnosis By Module
1. Access Service Mode
(In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode)
2. Check if there is an error in the DMD board
DDP1011 → TEST PATTERN → Press the right arrow key:
Options of FULL WHITE, BLACK, RED, GREEN and BLUE PATTERN are displayed on the screen.
If "Pattern" does not appear, this is a DMD board error.
3. Check if there is an error in the digital board before the DMD.
When the DMD board has been determined to be error free based on the test patterns:
FACTORY MODE → DNIe → TEST PATTERN normal display: no error in the digital board.
If "Pattern" does not appear, it may be from a DMD board or ATI error or there is an analog board malfunction.
4. Check if there is an error in the analog board.
Check for a power signal from the analog to the digital boards
Jul 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Televison & Video Logo
81 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
