Question about Asko Dishwashers
Asko dishwasher 2000 error code F2 and F7 - Asko Dishwashers
  • 641 Answers
SOURCE: F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
Posted on Jul 27, 2007
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
Clean out the pump...they tend to get clogged with grease...then poor washing up liquid in the strainer and poor a couple of kettles of boiling water in the strainer.
It worked for me on my Whirlpool dishwasher.
Posted on Feb 10, 2008
SOURCE: Whirlpool dishwasher ADP5962 F7 error code
f7 means lack of water. It could be caused from dirty (internal) filter or chocked water pipe
Posted on May 29, 2008
SOURCE: Asko Dishwasher F2 Error Flashing
This was very helpful! Only 2 weeks ago I replace the circulation pump on my Asko 1855. Today, when I turned the power on, the F2 error message appeared. I removed the face plates and discovered there was a lot of water in the drip pan. I found the cause to be a small leakage on one of the hose connections. After removing all the water, the water level switch worked properly.
Posted on Aug 17, 2008
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Sep 10, 2009 | Asko Dishwashers
Asko D3350 code F7
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Dec 21, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
161 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
