Question about Motorola Mobility DRC800 Universal Remote Control
I bought a rlc 1906 model rca tv and my cable box is a motorola with a drc 800 remote. I cant find a code to work for my tv, isd there one?
I have a rca rlc 1906 hdtv lost my remote and the avex urc A6 remote and none of the method work to program it
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 14, 2014 | Televison & Video
Find code to set motorola remote to westinghouse television
Hello
Setup codes for Westinghouse TV with Motorola DRC-400 series remote control are:
0623 & 0624
If the remote control is of DRC-450 series, codes are:
0463, 0623, 0624
OK.
Sep 13, 2011 | Televison & Video
RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Dec 08, 2009 | RCA L40HD36 40 in. LCD HDTV
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Still can't find a code for Electron LCDTV
You have joined the ranks of those who have several 'universal' remotes. They aren't. They are, at best, multidevice or multibrand remotes and even the 'learning' remotes don't learn from some originals. The use of the word 'universal' is a fraudulent nomenclature.
In looking at the product description, I noticed this:
"The DRC450 remote control is designed specifically to work with all Motorola and General Instrument Digital Cable Terminals."
It was then never designed to handle any updating.
You might try to obtain newer codes from the Motorola site for your model:
Motorola DRC-450
I didn't see any provisions for updating the code set via computer so it will likely never do what you want.
Jul 06, 2009 | Logitech Harmony 550 Remote Control
Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 13, 2009 | RCA Universal Remote Control
Need remote codes
Get the 8.00 rca universal remote at wal mart (model rcr312w) follow the auto scan instructions and it will work.  I just had this same problem, bought 4 universal remotes and this one worked!
May 18, 2009 | iLO IWT3206 TV
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Televison & Video Logo
740 people viewed this question
Top Motorola Mobility Televison & Video Experts
Electro Med Services...
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
